Prius 2007 doesn't start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Nizan Armoza, Apr 23, 2025.
  1. Nizan Armoza
    Nizan Armoza New Member
    Israel
    Luxury
    So few days ago my prius turned on, i drove 5 meters and it turned off.
    Now it doesn't turn on.
    All the dash lights are on, the STOP fuse is ok, but the prius doesn't start.
    The 12V battery is pretty new.
    Any suggestions?
  2. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    You have no "ready" indicator. The hybrid system does not turn on.
    There may be many reasons. Is it possible to make diagnostics using a scanner, Techstream program or a compatible adapter with a hybrid?
    Fuse AM2?
  3. Nizan Armoza
    Israel
    Luxury
    So what can be the solution?
    Is it something i can do by myself?
    I will check the fuse. Can you guide me where it is?
    About the scanner - i will try to find one.
    If you have anything else i can check let me know please
    #3 Nizan Armoza, Apr 23, 2025
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    Do the brake-stop lights come on when you push on the brake pedal?
  5. bisco
    52,697
    Did the engine ever fire up?
  6. Nizan Armoza
    Israel
    Luxury
    Yes
    What do you mean?
    #6 Nizan Armoza, Apr 23, 2025
  7. Nizan Armoza
    Israel
    Luxury
    I checked the AM2 fuse. Its ok.
    I am still looking for a scanner
  8. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    300 000mi:ROFLMAO:
  9. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    There may be many reasons for failure to start. For example, lack of gasoline or a non-working fuel pump.
    But before starting, the car checks the readiness of the hybrid system for operation. If all tests are passed, the car turns on and the "ready" sign lights up.
    When the tests are not passed, then further operation is not possible. There may be many reasons for failure in tests. A discharged 12V battery, a malfunction inside the high-voltage battery, a malfunction of the inverter, malfunction of other systems. Without a scanner and diagnostic error codes, it is almost impossible to find out the correct cause and the way to solve it.
  10. Brian1954
    Brian1954 Senior Member
    2,600
    1,031
    South Central PA, USA
    For information about some scanners, read this thread, https://priuschat.com/index.php?posts/3290690
    You want to purchase a scanner that can communicate with all the ECUs in the Prius.
  11. pasadena_commut
    pasadena_commut Senior Member
    2,981
    925
    Southern California
    While the OP is waiting for a scanner it would be a good time to check that there is oil in the motor, coolant in both the ICE and inverter loops (check at the radiator neck, not just in the overflow tank), and brake fluid in the reservoir. Also measure the 12V battery voltage, easiest at the jump point under the hood.
    The picture doesn't show the MFD. Is there a red triangle of death and a message?
  12. Nizan Armoza
    Israel
    Luxury
    I checked all of these and all seemed ok.
    About mfd, there is no message there
  13. bisco
    52,697
    i mean, did the engine start, or was the 5 meters on the electric motor
  14. Nizan Armoza
    Israel
    Luxury
    When the car died i dont think the engine started. Only the electric motor
  15. pasadena_commut
    2,981
    925
    Southern California
    This sounds like it may be one of those conventional "no air, no gas, or no spark" issues, and it is just complicated by the fact that the electrical side of the propulsion system is working.
