Prius 2007 Gass Gauge stuck
Discussion in 'Gen 2 Prius Technical Discussion' started by Ali Almourady, Jun 30, 2014.
  1. Ali Almourady
    Ali Almourady New Member
    Hey,
    Here's my problem the gass gauge is not working properly, it recently happened that it is stuck at 1 dot and it keeps flashing I filled the gas a couple of times and its still stuck at the same place it is really weird because it never happened I tried to re calibrate the sensor by the ODO Trip and it did not work any help would be appreciated, If I remove the battery would it help? for example would the sensor unstuck?
    Regards
    Ali Almourady
  2. JC91006
    16,672
    8,518
    How much gas do you put in on the fillups? If you put in 3 gallons or less, this can happen. You can Disconnect the negative on your battery for a few seconds to reset.
  3. Ali Almourady
    Thanks very much it worked I disconnected the battery and it worked.
    usnavystgc likes this.
  4. BellBoy
    BellBoy Member
    220
    I have something kind of similar...would the battery disconnect fix this issue?
    I've noticed that my gas gauge seems to be off for the last six months or so. I usually get around 42 MPG on my 2006 and around 430 miles per tank. Now when my add fuel warning goes off lately I'm around 330 miles!
    I just filled up today and the auto shutoff on the pump hit at around 8 gallons. I kept topping it off and was able to squeeze in about another gallon. Could this be a problem with the float inside the tank or something like what the OP mentioned?
  5. Ali Almourady
    Yes could be or you can re calibrate it
  6. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    On the second page of this thread is a procedure to recalibrate the fuel gauge. I have not tried it. It is also not recommended to top off the fuel tank by repeatedly clicking the nozzle. That can lead to soaking of the evap canister. The bladder in the GenII tank was just a bad idea, and was discontinued.
    False Fuel gauge readout? | PriusChat
  7. BellBoy
    BellBoy Member
    220
    How do you do that?
