Prius 2007 low power, slow charge, fast discharge
Discussion in 'Gen 2 Prius Main Forum' started by zinzet, Sep 22, 2025 at 7:42 PM.
  1. zinzet
    zinzet Junior Member
    Federal Way
    Hi everyone.
    Maybe someone will advise
    No codes on the dash, no codes on the techstream
    Prius 2007 has low power after 30mph, no power uphill, hard to achieve 60mph.
    1. Inverter pump - fine, coolant level - fine.
    2. Hybrid battery with battery ecm was taken out of perfectly running car.
    3. Engine ecm replaced.
    4 Hybrid ecm replaced.
    5. Transmission fluid level is fine.
    6. Transmission ecm replaced.
    7. Upstream oxygen sensor live data is the same in comparison to the perfect working prius.
    8. Inverter replaced.
    No changes after all this
    #1 zinzet, Sep 22, 2025 at 7:42 PM
  2. PriusCamper
    PriusCamper Senior Member
    12,323
    5,006
    Pacific Northwest, USA
    Usually this symptom is because the car has detected a problem and stored an error code and turned on warning lights on the dashboard, as well as shut down the hybrid system so you're running on the engine alone and no electric motor power.
    Please clarify the presence of dash lights as well as get the error codes read via an auto parts store, or use a $20 bluetooth OBD2 error code reader so you can use a phone app like Dr. Prius.
  3. zinzet
    Federal Way
  4. pasadena_commut
    pasadena_commut Senior Member
    2,451
    734
    Southern California
    SOC on the pack as shown on the display?
    Module voltages and the temperatures inside the pack?
    Is it an OEM pack?
    Are any of the brakes dragging? (One or more of the wheels should be dangerously hot after driving if this was the case.)
    Seems like this car has 3 ECMs from a donor car, possibly more than one donor. Were any of those from the first couple of model years? Toyota made some changes in 2006 (I think) and maybe earlier ECMs are somehow not fully compatible with the later years for this generation? It could even be something like a firmware mismatch.
  5. zinzet
    Federal Way
    No brake dragging. Ecms compatible, no changes with donor or original.
    Hybrid battery was taken out of the good running vehicle.
    #5 zinzet, Sep 22, 2025 at 8:16 PM
  6. pasadena_commut
    2,451
    734
    Southern California
    Not an answer to the question. Is it an OEM pack? How long ago was it transferred from the other vehicle?
