Prius 2007 Odometer
Discussion in 'Gen 2 Prius Technical Discussion' started by Hafiz muhammad adil, Sep 5, 2018.
  1. Hafiz muhammad adil
    Hafiz muhammad adil Junior Member
    Pakistan
    Hello Prius Expert,
    I am new to this group. I am having Prius 2007 imported from Japan. I am using it since 2013. From last week the odometer reading is stuck on 74575. What will be the possible cause and solution of it? Please note that Trip meter A & B are working fine and I am getting car driven reading on it.
    49,376
    welcome!
    sounds like a bad multi information display. might be a cold solder joint on the board or a bas capacitor.
    you will either need to get it repaired, or replaced, and from someone who has the authority to reset the odometer, if that is the law in pakistan.
    all the best!(y)
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    Never heard that before. It’s probably a bad dash board assembly ommonly referred to as the combo meter.
    Use the search forums button up top and search
    Combo meter
    There’s members on here that repair them or you can buy a rebuilt from some members also. You’ll see them mentioned when u search.
