Prius 2007 Stream music using bluetooth
Discussion in 'Newbie Forum' started by Raghav, Mar 12, 2013.
  1. Raghav
    Raghav Junior Member
    34
    Is it possible at all? I looked at answers to several similar question, but could not figure out exactly.
    My prius is 2007 pkg 6 with jbl speakers. When I register device, there is only option of hands free. Even my pda (LG GM730, windows mobile 6.1) shows hands free only.
    Does prius 2007 support streaming music using bluetooth?
    prius_nerd likes this.
  2. rovermeister
    rovermeister Junior Member
    UK
    I use a tunelink, it plugs into the lighter socket and connects to the aux port in the armrest. Then it connects to your phone by Bluetooth. You set the stereo to aux and you can stream from the phone to the stereo via the tunelink.
  3. billinmd
    billinmd Member
    184
    28
    Bel Air, MD
    2020 Prius Prime
    I am using the Griffin BlueTrip Aux in the 2009... Works great!
    iPad ? HD
  4. Raghav
    34
    Thanks guys. Essentially it needs a workaround. Direct audio connection to car bluetooth is not possible.
  5. Jamesb93612
    Jamesb93612 Member
    133
    69
    Clovis, Ca
    Thanks! I too have been looking for a solution to this problem. I will have to check out both of these.
    iPad ? HD
  6. steve_b
    steve_b New Member
    South Central PA.
    I was hoping to do that too, but couldn't figure it out either. I'm not sure but I don't think my '05 has an aux input for the radio. Just got the car a couple weks ago and the wife drives it most of the time so haven't been able to spend a whole lot of time with it so far.
  7. Jamesb93612
    Jamesb93612 Member
    133
    69
    Clovis, Ca
    Check in the center armrest console. Mine is there.
    iPad ? HD
  8. Sherri
    Sherri Junior Member
    Los Angeles
    I still have my 2007 Prius as a second car. Not being able to stream music drives me bananas when I use it tho..
    I was wondering if I use a Bluetooth streaming aux hookup, how does that work with the current hands free phone set up since the streaming device is also hands free phone ? Do you have to make or answer calls with both devices or does one automatically override?
    #8 Sherri, May 21, 2022
