Prius 2007 - Yuasa HJ-S34B20R 12V AGM battery is OK?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by IvanCS, Oct 28, 2025 at 5:11 AM.
  1. IvanCS
    IvanCS New Member
    Today
    Wycombe, UK
    My 12V battery needs replacing. Halfords (UK) recommend Yuasa HJ-S34B20R Auxiliary AGM Battery for my Prius 2007, but am not confident they are correct.
    Is there a table online or a way to check this first?
    Thanks, Ivan
  2. Hayslayer
    Hayslayer Member
    361
    202
    In North America, the 2007 with SKS uses the S46 battery, the model without SKS uses the S34. The S46 is just slightly larger and uses a slightly different mounting bracket. In reality, either battery can be used in either circumstance by modifying the bracket or ordering a new bracket from Toyota for about $25. The S46 has a bit more capacity to account for the extra electrical draw by the SKS system while the car is off.
  3. Tombukt2
    Tombukt2 Senior Member
    12,813
    2,303
    Durham NC
    Yuasa AGM is a great battery have em in my bikes . Kinda like old Deka
