Prius 2007
Discussion in 'Gen 2 Prius Main Forum' started by Kolso0713, Sep 29, 2021.
  1. Kolso0713
    Kolso0713 New Member
    New York
    I turn on the car the red triangle on the check engine pops on I put in drive the car don’t move I need to clear the codes with obd2 the simple one after that I can drive , If I’m not turning off the car all day never pops up the trangle and works perfectly fine if I’m shutting down the car when I start it does the same issue all the time what could be 2007 Prius 210000 mil
  2. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Welcome to PriusChat!!
    Do you have any OBD2 codes (DTCs) that you can post here?
    Sounds like you have a Hybrid Battery Voltage System Isolation Fault, aka P0AA6. You may just have a leaking module in the HV pack.
    Here is the workup for DTC P0AA6, notice the five related INFs, knowing the subcodes (INFs or detailed codes) may help narrow down the fault. : https://attachments.priuschat.com/attachment-files/2018/04/145252_2006_Prius_RM_-_P0AA6.pdf
    FYI: your posts are being moderated until you've posted 5 times.
