Prius 2008 front wheel bearing
Discussion in 'Gen 2 Prius Main Forum' started by Amer olimat, Sep 15, 2018.
  1. Amer olimat
    Amer olimat Junior Member
    Jordan
    I have a noise in the front wheel bearing at left side but I had changed it before 2 years with koyo bearing from my Toyota dealer but it failed again but don't know the reason.
  2. PriusCamper
    PriusCamper Senior Member
    11,105
    4,519
    Pacific Northwest, USA
    First most likely is the mechanic who inspected all the associated parts before installing the new wheel bearing failed you... Or they put the bearing in place in a dirty shop with dirty tools and dirt and grime caused it to fail prematurely. Complaining to them might get you a discount?
    Second option is that it's a specific driving condition on a specific road or parking spot and you beat the crap out of that wheel in the same way often.
    davecook89t likes this.
  3. First_Time_prius_owner
    First_Time_prius_owner Junior Member
    28
    23
    toronto
    I would buy a toyo bearing from rockauto.com and get the warranty figured out. either way , if you do the tire test (hands at 0 and 6 o clock) and it moves up and down, and then left and right, then cause its a bearing I would highly say you change it since its a safety issue.
  4. jimolson
    jimolson Member
    135
    55
    Indianapolis, USA
    I can echo the complaint of the original poster. I've replaced noisy wheel bearings in 3 different Priuses by 150k miles.
    The replacement bearings in the most recent one lasted a mere 8k miles before requiring a third set of bearings.
    The most recent bearing failure was interesting in that never progressed to the grinding noise phase. It hummed for more than 5k miles before I got annoyed enough to replace it.
  5. First_Time_prius_owner
    28
    23
    toronto
    So something to report. after about a year and 20k km the bearing i installed gave out :( it was this one More Information for TIMKEN HA590064
    Im hard pressed to blame the part since its a good part but not sure . it broke shy of 20 days of warranty, just as our winter turned to spring. so now i had to get my mechanic to put in a new bearing.
