Prius 2008 NAV Phone book
Discussion in 'Gen 2 Prius Audio and Electronics' started by mnky357us, Oct 5, 2007.
  1. mnky357us
    mnky357us bweverka
    42
    Cornelius, Oregon
    After looking at my 2008 manual, and doing some checking on the
    compatability of Bluetooth compatable phones. I find that Verizon
    has my phone locked out of data transfer of the phone book of
    my Razor V3.
    My question is: Does anyone know of a way to enter the phone
    numbers into the phone book manualy? I don't see anything in
    the book that says anything like that.
    Thanks for any help.
    Bob/Sharon
    2008 Seaside Pearl
    Package #5
  2. stukid
    stukid New Member
    30
    The six(?) speed dial entries. . .
    Or, dial from your phone and go off hook from the steering pad . . .
  3. Sarge
    Sarge Senior Member
    1,302
    758
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    <div class='quotetop'>QUOTE(Bob/Sharon @ Oct 5 2007, 11:06 PM) [snapback]522060[/snapback]</div>
    Hi Bob/Sharon,
    I noticed nobody has replied to you, but don't know why... :huh:
    Manually programming phone book entries is quite easy, and there are two ways to do it;
    - While stopped, press the off-hook button on the steering wheel, then press "Phone Book" on the MFP. You should see a Register 'soft' button at the top of the screen. Press it and go to town. :)
    or...
    - Also while stopped, press the Menu 'hard' button, then choose Phone Book (?) and register from there. I am in the car at the moment and am going from memory on that one...
    Good luck!
  4. mnky357us
    mnky357us bweverka
    42
    Cornelius, Oregon
    <div class='quotetop'>QUOTE(Sarge @ Oct 10 2007, 12:05 PM) [snapback]523679[/snapback]</div>
    Sarge, Thank you so much. Just tried it and worked great.
    Ok I just tried it and works great.... Thank You so very much.
    Thank You, Thank You, Thank You, Thank You, Thank You
    Bob & Sharon
  5. Prius07Pkg4
    Prius07Pkg4 New Member
    <div class='quotetop'>QUOTE(Bob/Sharon @ Oct 5 2007, 08:06 PM) [snapback]522060[/snapback]</div>
    With Verizon, send phone book one by one (I think it's called Vcard) quicker than enter manually to the system. You can search in this forums,
  6. Sarge
    Sarge Senior Member
    1,302
    758
    2023 Prius Prime
    XSE Premium
    <div class='quotetop'>QUOTE(Bob/Sharon @ Oct 14 2007, 11:24 AM) [snapback]525429[/snapback]</div>
    You are most welcome. B)
  7. mnky357us
    mnky357us bweverka
    42
    Cornelius, Oregon
    <div class='quotetop'>QUOTE(Prius07Pkg4 @ Oct 14 2007, 10:27 AM) [snapback]525431[/snapback]</div>
    That may be a little bit complicated for me....
    Thank You
    2008 Seaside pearl Package 5
  8. Prius07Pkg4
    <div class='quotetop'>QUOTE(Bob/Sharon @ Oct 15 2007, 01:10 PM) [snapback]525982[/snapback]</div>
    For LG VX8300 (Verizon), you can send 10 name cards at a time, for example you have 82 names in your phone book you need to transfer 9 times.
    1-Pairing then Set up the car bluetooth so your car bluetooth is transfering ( you can use your Prius user manual).
    2-Menu -> Setting&Tools -> Bluetooth -> HighlightyourcarbluetoothName HANDS FREE ->options->Send Name Card -> Mark ten name at a time -> Done
    3-Mark ten names again -> Done
    4-Continue Step 3 till all names are tranfered.
  9. aaf709
    3,862
    2022 Prius Prime
    The 2005 doesn't have manual entry of phone numbers. I got a cheap non-Verizon BT phone off of eBay, put the numbers in that and sent the numbers that way.
    You can also do that if you have a laptop with BT.
