Prius 2008 problem with Pics
Discussion in 'Gen 2 Prius Main Forum' started by oldngold, Jan 7, 2017.
  1. oldngold
    oldngold New Member
    norway
    Big problem n still i have no idea what to do, i have prius 2008. Actually it starts when my prius 2008 stopped and show some errors and after some while my car key stopped working so it tried to use direct key for open door and my friend told me that these is a problem in my 12v battery and we replaced it but after replaced battery my prius 2008 does not start engine and it shows these error.. see pictures
    can anyone tell me what is the problem with my prius 2008??? help me please i shall thankful :)
  2. JC91006
    16,482
    8,400
    You need to get the codes read
    oldngold likes this.
  3. oldngold
    oldngold New Member
    norway
    Well problem solved :) ... admin you can close this thread :)
    49,488
    i suspected that might be the problem, but i figured you already checked something that simple.
  5. bisco
    49,488
    thread closed. (picture of padlock)
  6. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,220
    Madison, Wisconsin
    Wait. What was the solution?
    edthefox5 likes this.
  7. bisco
    49,488
    too late, the pad has been locked.
  8. oldngold
    oldngold New Member
    norway
    well here is the solution, i pressed parking for 1 min then i pressed parking button and power button same time for 10 sec, then under wheels steering there is reset button i pressed and wait 15 sec, then i unplug battery fuse which is back of the car and plug it back after 10 sec, after that i start my car and it works:) hope you understand, if any question reply here i try my best to explain :)
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Looney tunes thread
    m.wynn likes this.
  10. bisco
    49,488
    that's exactly what i was going to suggest, but it seemed too obvious.
  11. dolj
    dolj Senior Member
    7,653
    3,867
    Wellington, New Zealand
    Could have saved himself all that bother if he just disconnected the 12 V battery in the first place.
    But actually, if that is all he did, he hasn't fixed anything. Just erased the codes. "They'll be back"
    m.wynn and valde3 like this.
  12. bisco
    49,488
    you're saying the reset under the steering wheel isn't an integral part of the procedure?(n)
  13. ericbecky
    4,371
    3,220
    Madison, Wisconsin
    Hmm... weird.... Usually you must also spin around three times and clap your hands twice. :)
    I'm kidding, I'm kidding.
    Glad it worked out for you and thank for replying OP
    edthefox5 and bisco like this.
  14. bisco
    49,488
    good thing you added the kidding part, i was going to try it.
  15. ericbecky
    4,371
    3,220
    Madison, Wisconsin
    Realistically the codes could have been inadvertently been set while installing the 12v.
    So simply clearing them after the install was completed would have been all that was needed.
    Time will tell.
