Prius 20099 problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Priuslover09, Jan 9, 2020.
  1. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    My friend has theses codes he says on the 2009 Prius PU0293 B1651 P0305 P0560 P1455 P0A95 P31AB P0A09 P3190 P0300 P3030 P2237 p261b P0174 P0171 po886 p0893 p117 P0420 p2402 p0036 p0038 p0003 P0604 P0560 p0000 P0606 P1150 C0076 P0215 P0210 C0077 P1120 C1203 C1344
    Is it worth taking taking to passport Toyota in camp springs? The car was bought in 2011.
  2. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    His name is phineas Flynn. He lives in Danville md. He’s 23 now. He let his car sit October 30th- January 7th. He kept the car in his garage because he was driving the Jeep wrangler truck he bought earlier that month. Idk why but he sound like phineas Flynn from phineas and ferb but he’s not. LOL!!!
    #2 Priuslover09, Jan 10, 2020
  3. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Which device was used to read the above DTCs (codes) with?
    How is the 12v health, and does it currently drive?
    m.wynn likes this.
  4. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    The 12v doesn’t work and I think it was a computer that read the codes
  5. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Guessing it doesn't drive, since you didn't answer the question.
    If the 12v battery "doesn't work" or has failed, try charging it, otherwise remove it and take it to a parts shop for charging/testing.
    Without a working 12v battery the vehicle won't even "boot up", much less drive.
    Raytheeagle and m.wynn like this.
  6. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Ok I’ll try to get it to a shop by tomorrow I’ll need a tow truck.
  7. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    You shouldn't need a tow truck to remove a 12v battery.
    Have you already tried recharging?
  8. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    I did try jump starting the hybrid battery and the 12v
  9. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    How did you jump start it, did you use the jump points under the hood or did you go straight to the 12v in the rear?
  10. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Straight to the 12v
  11. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    When jumping or applying 12v to the battery in the rear, did the vehicle go into 'ready' mode?
  12. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    It was stuck in Neutral
  13. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Still sounds like a low voltage 12v battery issue, were there any lights on the dash that you remember?
    Try adding 12v again (donor car shouldn't be running), then check the voltage at the "jump points" under the hood.
    #13 SFO, Jan 15, 2020
  14. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
  15. eternalphoenix64
    eternalphoenix64 Junior Member
    44
    Battle Ground, WA
    SFO, I tried messaging you, but I guess being a new member even those aren't going through. I've had a post in Gen2 troubleshooting that's been pending approval for 36+ hours now. Any chance you can message me or something and we can talk about my problems? It seems like you're fairly knowledgeable about various problems. My situation is a bit unique, not the standard VSC/ABS/((!))/BRAKE problem. I have codes and 12V test results I can share.
    SFO likes this.
  16. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Napa sold me a Refurbished 12v battery at 11.9 V so I’m Assuming it has half the charge when the 12v was brand new. hybrid battery keeps going down to purple every 4 minutes. The codes the dealer gave where false when i got creader 3001 scanner I bought from Napa I only have p3002 p0A80 p0000 P3030 C0077 P0420 P0A94 CC076 P1150 PC1349 p0893 the muffler sounds too loud when starting the engine but I wondered where the dealership got the other codes from?
    #16 Priuslover09, Jan 15, 2020
  17. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
  18. bisco
    51,140
    dealer has a proper prius code reader. get your 12v up to snuff first
  19. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    I don’t think the dealer is the problem! And what do you mean the 12v to snuff up?
  20. bisco
    51,140
    i think i saw phineas in his jeep truck on the beltway today, sharp
