Prius 2010 - aircon is not cool when engine kick in
Discussion in 'Gen 3 Prius Main Forum' started by sanlen, May 13, 2024.
  1. sanlen
    sanlen Junior Member
    42
    Phnom Penh
    Hello everyone,
    I'm encountering an issue with the air conditioning in my Prius 2010 when the engine kicks in. The air conditioning operates perfectly fine when the car is running solely on battery power. However, whenever the engine starts, the air conditioning's cooling effectiveness diminishes.
    Could you please advise on what the potential problem might be?
    Thank you in advance for your advice.
    Best regards,
    sanlen
  2. ChapmanF
    15,649
    Such an issue frequently comes down to the "air mix door" (also called "blend door") inside the HVAC unit under the dash.
    The door controls temperature when heating, by adjusting how much air goes through the engine-coolant-heated heater core, and how much goes around it. When you want cooling, the air mix door ought to move so that all the airflow goes around the heater core and none goes through it.
    If the door is staying in the "air goes through the heater core" position, then you will have cold air when the engine is stopped, but reheated air when the engine is running.
    With a bit of searching you can find a lot of threads here on diagnosing and repairing that.
  3. Tombukt2
    Tombukt2 Senior Member
    9,143
    1,601
    Durham NC
    I think in a pitch there may be a way to push it open or pull it closed whichever it needs to be but I don't know this for a fact just speaking from myriads of car experience You probably have a good bit of taking apart to do to actually get at the part but. And be careful touching every little piece under there everything will break if you barely look at it Just be very careful and work very slow there are no shortcuts these cars are built so that most everything has to come apart to get at many of the simplest things.
  4. ChapmanF
    15,649
    In a gen 2 you can reach the actuator by kinda standing on your head in front of the driver's seat, not taking very much apart. There are threads about this. Member yitznewton found a tool that was handy because the skid ECU was kind of in the way.
  5. Tombukt2
    9,143
    1,601
    Durham NC
    Yeah I'm thinking about this guy's Gen 3 I know mine is not going to be that huge of a problem matter of fact it stopped hunting for a while so I haven't done anything about it till I can yank another one off another car and clean it up and see what the real deal is tin whiskers whatever I don't know.
  6. ChapmanF
    15,649
    Yeah, there were some threads about gen 3 too. Some people succeeded with some inventive alternatives to a lot of disassembly—but whether those'll work may depend on exactly what's gone wrong.
    Tombukt2 likes this.
