Prius 2010 cylinder 1 misfire query
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by GI HEON YUN, Aug 17, 2019.
  1. GI HEON YUN
    GI HEON YUN New Member
    Seoul, Korea
    My Prius 2010 Continuous Misfire Cylinder 1
    List of actions taken.
    1.Oil Catch Can
    2.Fuel Injector x 4 Replacement (by Remanufactured)
    3.Spark Plug x 4 Replacement (by Genuine Toyota)
    4.PCV Valve Replacement
    5.Intake Manifold Cleaning
    6.EGR Valve, Cooler Cleaning
    7. Coolant Replacement
    A total of seven have been progressed, but Misfire is continuously coming out.
    Total 93K Mile (150,000KM)
    Coolant, Engine Oil No Leak.
    Coolant Temp 194 ~ 200F
    This picture was taken after the misfire was made.
    The first picture is cylinder 1
    The rest of the pictures are cylinders 2, 3, 4 (same)
    Is the head gasket problem even if the oil and coolant are not leaking?
    Please help me
    52,820
  3. schmuber
    schmuber Member
    115
    85
    Georgia
    Yeah, start with swapping coils 1 and 2, then see if misfire moves to the 2nd cylinder.
    Pluggo likes this.
  4. bikes4u
    bikes4u Member
    131
    39
    indianapolis
    When you unplug the electrical connector to the egr valve does it still misfire?
  5. wheezyglider
    wheezyglider Active Member
    247
    178
    SF Bay Area
    That's a strange looking buildup on the intake valves of only cylinder 1. I'd guess that the intake valve seals are leaking in that cylinder. But I have to wonder if some kind of oil additive was used. Maybe a walnut shell cleaning would help with the misfire. (But not fix the leaking valve seals, if that's what's happening.)
    Pluggo likes this.
  6. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    Total agreement. Also, be sure you are using any of the cleaner burning fuels certified as Top Tier.
  7. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    The funky buildup in cylinder 1 could be due to the misfire. If the fuel isn't burning, it will leave a residue.
    mjoo and Pluggo like this.
  8. wheezyglider
    247
    178
    SF Bay Area
    I like that explanation. But why isn't it getting cleaned by fuel? It's not leaving the typical clean/dirty pattern where the fuel injector's spray does and doesn't reach? And OP said fuel injectors were replaced...
    mjoo likes this.
  9. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Fuel injectors were replaced, but the misfire remains. That means this cylinder is not burning its fuel. So you would expect this one to appear different than the firing cylinders.
  10. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Were the EGR ports in the intake manifold cleaned out?
    Pixel XL ?
    Mendel Leisk and Raytheeagle like this.
  11. GI HEON YUN
    Seoul, Korea
    The Head gasket near cylinder # 1 is out. I paid 1000 $. T.T
  12. Mendel Leisk
    42,323
    Not sure what you mean. Has it been determined there's a failure of the head gasket, at cylinder #1? And it's been replaced, at a cost of $1000?
  13. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Sounds like it.
  14. wheezyglider
    247
    178
    SF Bay Area
    At only 93K miles, that's a very early head gasket failure. Thanks OP for posting the resolution.
    The Critic likes this.
