Prius 2010 difficulties by start
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Stuzia, Jul 22, 2019.
  1. Stuzia
    Stuzia New Member
    Germany
    I have a Problem with my Prius 3 2010. Sometimes difficult start- Navigation vanish and Motor cannot be started so I have to use emergency start. Sometimes no Problem.
    I let it twice chek up in car Service but nothing was found. I was advised to buy a new battery but it is still good(also checked).
    Can anyone help me.
    There is a link to short video
    we.tl/t-i9k0nVskqj
    51,154
    maybe a loose battery connection, check for cleanliness and tightness, especially negative to ground
  3. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Do a load test
  4. Stuzia
    Stuzia New Member
    Germany
    Check battery before starts 8,5 V. After starts immediately 13,5
  5. bisco
    51,154
    that's dead. should be at least 12.4 before it comes on. the reading after is from the converter
  6. Stuzia
    Stuzia New Member
    Germany
    Today morning with Emergency Start must I use. And after work I succeed to start without anything to help - simply Start button and all is ok. Any explanation please...
  7. tankyuong
    1,555
    661
    Central MO
    Just get a battery already
    Mendel Leisk and ThatDudeOrion like this.
  8. Mendel Leisk
    40,582
    Yeah, is this the original battery? And with the car off it's reading 8.5 volts? It's time to replace.
  9. Stuzia
    Stuzia New Member
    Germany
    Thank you for your answer. I was by two toyota service stations for battery check. They said, they will not replace the battery, because it good is.
  10. schmuber
    schmuber Member
    115
    84
    Georgia
    Proper auxiliary battery must you get, young padawan.
  11. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    Ihre Batterie ist tot, mein Herr. :)
