prius 2010 hybrid batteries dead at 126000km and up on atleast 3 taxis i know of
Discussion in 'Gen 3 Prius Main Forum' started by socratesthecabdriver, Dec 14, 2011.
  1. socratesthecabdriver
    283
    31
    greece
    i was just alerted on hybrid battery deaths today talking to my neighbor !!! he is changing his battery at 170000 km!!! the dealer told him the problem was that the fan that cools the battery down got clogged up with lint and such thus not being able to cool the battery down !!!
    now my neighbor which is also a taxi owner told me another cabdriver had the same problem with his and that i should look out for my own taxi and have my fan cleaned periodically !!!!!!!!!!
    its needles to say that the first thing i did after i finished talking to him was call my service manager and tell him the run down ! he gave me some run around that no need to worry and that they would do that maintenance as scheduled anyway (yea ok!) and that that would not have being the cause of the default of the batteries in any ways !!
    i started alerting fellow prius taxi owners and i came up one more cabby that had the same issue and changed the hybrid pack and fan at 126000 km and also was told that it was because of the fan !!!!!!!!!!
    HELLOOOOOOOOOOOOOOOOO IS GREECE THE ONLY PLACE WITH HYBRID PACK PROBLEMS!!!!!!!!!!!!!!!!!?
    2 people like this.
  2. walter Lee
    1,126
    376
    Maryland
    How many months was the 126000 km (78k miles) 2010 Prius taxi in service before it had to have its battery pack and fan replace? There is a possiblity that the length of time your taxi was in service and not the mileage could be a better risk indicator when the fan & HV battery might fail. I have a ScangaugeII which I currently monitor the State of Charge (SoC) with it but I know it can monitor other HV battery components like the Inverter Coolant levels. Sofar I've had my 2010 Prius for about 19 months (+17800 miles/28646 km) and I haven't had any trouble with the battery; however, my Prius gets far less usage than one used as a taxi.
  3. socratesthecabdriver
    283
    31
    greece
    just a bit over a year
  4. austingreen
    austingreen Senior Member
    13,591
    4,132
    Austin, TX, USA
    I would hope that toyota would at least partially cover those batteries under warranty. I don't think they thought the fans would get clogged, but neither should the owners. How long is the warranty in Greece, its 160,000 km here, and 240,000km in some states.
    Thanks for the heads up. You may not be hearing it from other places as they don't get as warm as Greece though it is warmer here, and there will be fewer complaints if toyota is replacing the battery for free.
  5. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    This is very common with Gen II, in Taxis and driving instructor vehicles. Gen III hv battery has the added problem of high power rating, which makes cooling even more important. I suggest you clean your vent once a month. Many people have constructed filters at the intake to capture lint.
    EDIT: I have posted a TSB later on in this thread with the recommendation from Toyota to clean the fan every 25,000 miles for vehicles that experience severe usage i.e. taxis.
    http://priuschat.com/forums/gen-iii...-up-atleast-3-taxis-i-know-8.html#post1451701
  6. bisco
    49,693
    amazing that dealers all over the world are exactly the same. do they all train at the same university? :mmph:
  7. socratesthecabdriver
    283
    31
    greece
    160,000 km here
    IF IT IS VERY COMMON WHY ISNT IT MENTIONED AS MUCH AS IT SHOULD??????:confused:
    mind boggling !!!!!!!!!!!
  8. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    It is a problem in taxis and other cars where the back seat is almost always occupied, also for people that travel with pets. But that is a very small fraction of worldwide ownership.
  9. pauln64
    pauln64 Junior Member
    77
    Macon, GA
    Any pics of such filters and how do you go about cleaning the vent.
  10. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Add to that the fact that it's more of a problem in places with high temperatures and you shrink the numbers further. Still, given the positive press Toyota gets from Prius taxis that they'd be keen to make sure taxi drivers are aware of their particular issues.
  11. pederson80
    pederson80 New Member
    Cambridge, Wi
    Where is the vent located? I'm guessing using a cut to fit furnace filter would work? Or what would you suggest?
  12. Mendel Leisk
    38,873
    I put a piece of vaccuum cleaner motor filter across the intake on ours. Doesn't seem to have caused any problems, and it has picked up some airborne lint and seeds. I also got down to the fan to have a look:
    gen 3 hybrid battery cooling fan dust buildup | PriusChat
    <Sept/2012 comment: the pictures in the above link are apparently lost since the site upgrade, sorry. May repost, but frustrating.>
    I do think it's a good idea to check on it periodically.
  13. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    A common complaint in taxis eh? You show me ONE complaint on here other than the op where this is the case.
    I understood the Prius is supposed to be very reliable as a cab as proved by that cab company in Vancouver where a cab ran to 1,000,000 km without issue.
    I am only at 63,000miles (101,000 km) and not had much issue with the HV battery - yet. It is much cooler here in the UK (30c or over is rare) and I have only heard the HV battery fan once. You can feel it running on low speed if you hold your hand over it though.
    (Just a quick thought. Could it be people blocking the vent when they sit in the car? In the UK, a RHD country, the passenger will usually sit in the back on the opposite side to the driver or in the front. In a LHD car I assume they will do the same, but in doing so will block the vent? Most of my fares are individuals.)
  14. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    Please look at the following blog post from Luscious Garage. How similar is climate in San Francisco compared to the UK? Anyway, Grumpy, I strongly encourage you to make periodic checks to your hybrid venting system. One a battery overheats a few times, its capacity is severely diminished.
    Luscious Garage | Blog | Prius battery cooling fan cleaning, P0A82
    GardenWeasel and GrumpyCabbie like this.
  15. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Well it's the first instance I've heard in that it was a common problem to cabs and the only link you provided was to one website, however, it was a helpful link and the pictures on there were quite alarming.
    I've just gone past the 60k mile service but will have the dealers take out the fan and clean it (and show me it) at the 70k service point.
    Perhaps it's worth me for sending an article to the UK monthly taxi magazine so that at least owners are aware of the issue - and leave it up to them to sort as they see fit.
    I'm still convinced it's a hot climate issue and that LHD passengers will block the vent more than over here. I do notice that if the vent IS bloked by a passenger on a long run, the HV battery indicator will stick up at 7/8 bars and the economy drops a little. If this is happening a lot in a LHD car, then sure it can't be doing the battery any good.
  16. Rebound
    Rebound Senior Member
    3,964
    2,615
    Portland, OR
    The photo on the Luscious Garage site shows a fan that's definitely accumulated a substantial amount of gunk. Cleaning seems like a good idea. If I get to mine, I'll take photos. I don't haul large dogs in my Prius, but I haul kids who might jam Crayolas in that vent.
  17. AllenZ
    AllenZ Active Member
    640
    63
    Chicago
    Where is the cooling fan in Gen 2 Prius? Can someone take a picture of the position? Thanks!
  18. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    With my Gen III coming up to 110,000kms, I just removed my fan and checked it. There was a thin film of dust on the blades but no lint etc. Quick blow with the compressor and re installed it. I travel very dusty conditions here in rural Oz but never have animals other than rellies in the car.
    It just occurred to me that the cabin filter probably plays a part in reducing dust etc.
  19. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    I think it's probably because some of the cabs don't change their cabin filter (or remove it completely) or that they don't vac their car out as often as they should. Also, it could just be that when you carry lots and lots of different people you're going to get lots of fluff from their clothing etc that you wouldn't get in a normal car.
    I do keep my car looking mint on the inside and have often manipulated the vacuum hose to try and suck any dust/hairs from inside the vent.
    I'll see at next service.
  20. Agape
    Agape Member
    378
    Ireland/Eire
    Here is the link how to clean the fan on GenII I would imagine GenII/GenIII owners would at least need some sort of the pollen filter applied at the entrance to the vent (self made of course).
    I am going to look into this in my car shortly
    http://priuschat.com/forums/gen-ii-...-fur-dirt-causing-major-battery-problems.html
    Here is mine at 146,000km's:
