Prius 2010 - transmission oil change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Naushi Hussain, May 18, 2015.
  1. Naushi Hussain
    Naushi Hussain Junior Member
    16
    Fountain HIlls AZ
    My oil transmission is overdue. I went to two mechanics and they don't do it since it is complicated. Shell Rapid lube who do all kind of oil changes wont touch a Prius. I like to avoid going to the dealer. Can anyone suggest where to go. I am in Phoenix AZ.
  2. JC91006
    16,477
    8,394
    Whichever place you end up going to (that's not a dealer), make sure you look at the fuid they are putting in. The bottle should say Toyota (WS) Fluid. Nothing else should go in your car.........
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    why don't you do this yourself? it's just a drain and refill.
    49,397
    i would buy the fluid and take it to a triple a mech.
  5. Mendel Leisk
    38,653
    Some Canadian members were getting it done through dealership for $79.95 (can). Don't reject the idea of dealership without at least giving them a try: they're the guys with Toyota ATF-WS fluid. It's unfortunately not a scheduled maintenance, so their openness and knowledge varies.
    That said it is an easy DIY. The main thing is you need to raise AND level the car. The simplest way to get the new fluid in is with a funnel and 3' extension tube. I've done DIY a couple of times now, not that hard.
  6. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    Sunday I finally did the dreaded ATF-WS change. The hardest parts were getting the car high enough, getting it level (on a diagonally inclined parking lot), and dealing with the confounded underpanel and its many fasteners. In comparison, the actual oil change was, as you say, easy, using the hose-and-funnel method.
    3.05 quarts came out and 3.35 went in. The old stuff was black (as others have reported), but contained no visible particles I could find, even after stirring it with a small magnet. As far as I know, this was the first time it has been changed, at about 48K.
  7. Mendel Leisk
    38,653
    Was the driveway near steep enough to raise one end only? Be sure to use significant, carefully placed wheel chocks when on a slope. Not just rocks or random piece of timber; get some solid rubber ones.
    If you can swing it, a level slab is optimum. Or a lift, lol.
    If you use that interval again, t suspect the next drain will look cleaner: the first seems the worst. I changed ours at first year and third year points, roughly doing 12000 kms per year. Yeah don't laugh.
    Anyway, second change seemed too soon: drained fluid was cleaner looking.
    #7 Mendel Leisk, May 19, 2015
  8. Naushi Hussain
    16
    Fountain HIlls AZ
    thank you every one I called a dealer and they would do it for $119 which is not bad but then he said that I need to change engine coolant and the hybrid coolant all totaling to $370. I have 90k miles and the engine coolant is due at 100k. I don't see hybrid coolant schedule anywhere. Can anyone suggest.
  9. JC91006
    16,477
    8,394
    $370 holy cow. You can diy all those in 1 afternoon
    Hybrid coolant is the inverter coolant. All the coolant should be replaced at 100k
  10. Mendel Leisk
    38,653
    On page 51 of the (US) Warranty and Maintenance Guide, footnote #3 says:
    Initial engine coolant replacement at 100,000 miles/120 months. Replace every 50,000 miles/60 months thereafter.
    Initial inverter coolant replacement at 150,000 miles/180 months. Replace every 50,000 miles/60 months thereafter.
    This footnote is cited in the 100,000 mile maintenance description, on page 50. Confusing as heck, but it's there.
  11. JC91006
    16,477
    8,394
    Nice to know inverter coolant is at 150k. I wonder if that's Canada only
  12. Mendel Leisk
    38,653
    That's the US schedule. Just looked up the Canadian, in the 2014 booklet they're saying:
    160,000 km / 120 months, then every 80,000 km / 60 months
    For both engine and inverter circuits. Those km values are same as US engine coolant change in miles.
  13. Patrick Wong
    18,200
    6,472
    There even is a sticker on the inverter coolant reservoir regarding the 150K mile change interval.
  14. JC91006
    16,477
    8,394
    Nice to know that too
