Prius 2010 vs Lexus CT200h
Discussion in 'Gen 3 Prius Main Forum' started by pakitt, Apr 30, 2011.
  1. pakitt
    pakitt Senior Member
    2,173
    1,311
    Colorado
    I did a test drive today on a Lexus CT200h.
    Here you can find my informal "review".
    Please let me know if you have questions, spot errors, or you want me to further elaborate on anything that I have written that is either not clear or not detailed enough.
    Thanks.
    6 people like this.
    48,942
    great write up, thanks! sounds disappointing from my perspective. i was really hoping for a quieter more comfortible prius, without all the other stuff. not interested in sporty driving or a smaller vehicle.
  3. Thai
    Thai Prius Neophyte
    1,197
    89
    Good review.
    BTW, guys, i love my Ecopia EP100...a bit quieter than my stock Toyos! :)
  4. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    As you mentioned, it seems a joystick / mouse pointer would be quite distracting to use in car. It's not a laptop, it's a car.
  5. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Haven't had a chance to read the review but I had a free test drive of the HS 250h for a week and it had the force feedback mouse-like controller. At first, I thought it was a terrible idea, would suck and that the LCD should be a touchscreen, as a backup.
    But, after I got used to it, I actually felt it wasn't too bad.
  6. 32kcolors
    32kcolors Senior Member
    5,683
    952
    124
    Redondo Beach, CA
    The remote touch control will come to future generation Prius, as features found in Lexus eventually trickle down to Toyota so better get used to this idea.
  7. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    thing to note is that in Europe, performance dampers are only in Sport model CT200h.
    Also - what is the price of Prius vs CT200h in Germany? In Croatia, CT200h is excellently priced, very similar to Prius price.
    So unless you need more space, CT200h is definitely better choice since it solves biggest Prius problem - materials.
  8. Thai
    Thai Prius Neophyte
    1,197
    89
    The Prius solves the biggest CT's problems - efficiency and practicality.
  9. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Too bad you could not take it to a longer test in narrow and winding roads, it has double wishbone rear suspension and other testers said handling is way much better. In fact Lexus guys say it is one of its strong features.
    Much more factory settings can be modified by user, including tachometer (you can set it to always off).
    SPORT mode is different from Prius POWER mode, apart from changing throttle mapping, in SPORT mode steering is tuned to more "firm", stability and traction controls are tuned to be less intrusive.
    Front seats are way better.
    The CT is about 40 kg heavier and with CD of 0.28-0.29, yet the fuel consumption is about the same (at least in the Euro test cycle), I wonder if it has some "evolutionary" improvements to the drive train in order to achieve this.
    Giora.
  10. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    This has been a recent talking point for some of my more knowledgeable passengers. "Why does the Prius look so awful" they ask? "Ah well, it's because of aerodynamics to make the car much more fuel efficient I would answer". "So how come the Auris HSD and the Lexus ct200h are just as fuel efficient but they look 'normal' "they reply. And do you know, I have no idea.
    Is the Prius shape just a gimmick? Sure it might have a very low drag coefficient but is it actually needed because the Auris HSD gets better fuel economy and the Lexus ct200h only a mile per gallon worse and both of those cars don't look 'weird' (in the eyes of my passengers).
  11. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    The following theory keeps sneaking to my mind:
    Auto manufacturers are smart.
    Auris HSD and Lexus CT200h are meant mainly to Europe.
    O.K. they say, let's tune them to be optimal for the Euro test cycle...
    Same with safety. Manufacturers aim to the safety tests! does this means the cars are more safe? probably yes, but mainly in the aspects tested...
    Giora.
  12. pakitt
    2,173
    1,311
    Colorado
    Well, I did manage to have the wheels spin for a split second starting from a Stop, with Sport mode while turning left onto a main road - but I managed to do the same with Prius in PWR mode.... ;)
    Honestly - if all that is reported, as you mention above, is true, I could not notice it at least for my driving and roads I manage to get onto. Yes the steering wheel is "stiffer", but not a major change compared to my Prius with the 215/45 R17 wheels. Surely if you drive the 15" wheels and get onto a CT you will notice a bigger difference, in handling as well. (this is also the reason I bought the Prius with 17" wheels rather than the 15").
    The Prius 2010 was designed at least around 2005-6 - it takes at least 3 years to develop a new car, if you are not starting from scratch. The current HSD drive was likely started to be development even earlier, likely in 2005 - you need up to 5 years to develop a new drivetrain, and they did not start completely from scratch - I am being conservative here and say they needed 4 years.
    What I am trying to say here, is that Auris and the CT have come out almost 2 years later, with a ready made HSD; it might well be that small refinements here and there have been added to the body, materials, and why not the HSD as well (but I really doubt about it - maybe Lexus has done some *really* minor changes - *never ever* change the software of a powertrain that works - never, especially if it took you 4-5 years to take it into production - there is a lot at stake when you make changes there, a lot), managing to get that 0.1L/100km difference or not difference with a slightly heavier car (40kg more, is only about 2-3% of the overall weight - you get an overweight passenger on one of these cars, and your fuel consumption is ruined... ;) ).
    Not to mention that 40kg difference might not play a major role in the test - and 0.1L/100km in real life fuel consumption is practically "noise".
    Nevertheless it would be interesting what they did really change - but we will never know... ;)
    So for the Prius 2010 in 2006 to get the current fuel consumption, the Cx and "weird" shape was necessary - today they likely don't need that much more. Moreover, the Cx is really important at high speed - which is not what the EU tests check. Suburban is not 120km/h on the highway, nor city and combined - as far as I know. And that is when Cx really plays a role. So what would be the fuel consumption of the Auris and the CT at those speeds?
    I need to check what Quattroruote.it in Italy measured on their track at 130km/h (the max allowed speed on italian highways) to know exactly if something is going on. I will let you know.
    And guys, the current Prius is not at all that ugly (Gen 2 was *really* ugly, to my very personal taste and opinion) and I have not heard many positive comments on the Auris either (my mum thinks it is *plain ugly* - and she is fierce with comments on cars.... :), as well as several other friends - it never really sold well here in Germany or Italy). The CT looks better, but it is no Audi either - I mean, Japanese are not really known for the looks of their cars...do they?
  13. pakitt
    2,173
    1,311
    Colorado
    The base model price of the Prius is 25750€ (you can play with the prices - up to 29050€ net of any additional option of the "Executive" version, here)
    The base model price of the CT200h is 28900€ (you can play with the prices - up to 40850€ net of any additional options on the "Impression Line" version, here)
    BTW - I have just seen in the LEXUS - LEXUS Deutschland website that the base model of the CT gets 15" wheels that look like those of the Prius!!! I wonder what the handling of that CT version would be - the same as the Prius!?!?! :D
  14. Thai
    Thai Prius Neophyte
    1,197
    89
    Handling may be a tiny bit better, but it is far, far, far from being anywhere near sports car territory! Slalom testing does not really reflect what Lexus claims. Road feel? Nope. Firmer steering does not always mean more road feel nor better handling. Braking? Not any better. Definitely not acceleration...where the CT is the same or a bit slower than Prius.
    Remember, Prius with 17" rims have brushless steering motor that allows for significantly quicker steering ratio!! Maybe that is why Pakitt did not notice much difference!
    Stability control less intrusive? That may be the ONLY thing that separates the CT from the Prius in the slalom. I would bet that this part (VSC less intrusive) is what makes the biggest difference in handling over a Prius, and not the double wishbone nor Sport mode. Personally, if i wanted a little handler, then i would pick something else...not one that takes over 10 seconds to get to 60 mph.
    European cycle is notorious for being inaccurate! Just ask VW TDI owners! US EPA ratings from 2008 are very accurate to the average driver. And according to EPA, there is an 8 mpg difference b/w CT and Prius.
    CT looks normal...because it blends in with any hatchback. Nothing revolutionary about it...nor does its shape give it any special aerodynamic features.
    Prius gets 0.25 Cd.
    Ct200h gets 0.29 Cd.
    BTW, more and more cars are achieving around 0.29 Cd...see 2012 Mercedes C class. But, it is exceedingly hard to achieve Cd as low as the Prius.
    In the end, the CT still is an average looking car, with very average handling, piss poor acceleration, and very impractical...and good (but not great) efficiency.
    Goes back to what i wrote earlier: The Prius solves the biggest CT's problems - efficiency and practicality.
  15. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Grummpy,
    Which of the anwers to your question you liked best?
  16. SmogSlide
    SmogSlide Member
    128
    17
    Melbourne
    I always thought that the MPG test cycle that the US agency used is more accurate/realistic than the one used in EU/Aus. The CT is rated at 42mpg (5.6l/100km), whereas the Prius is at 50mpg (4.7l/100km) in the US, a big difference of 8mpg! Who knows what the Auris gets if tested on US' soil? The Auris may even be around 42 to 44 mpg mark...
  17. Jim Clark
    Jim Clark Member
    310
    22
    Northern VA, the 51st state (someday)
    Do the higher trim levels have usual Lexus gadgets like power/memory seats, mirrors, and steering wheel? Also auto dimming and heated mirrors?
    With what you said about the power and handling of the CT (marginally better than Prius at best) and the smaller interior volume, the CT does not look like a winner. Also, if you go with the highest trim level package (there are 5 in the US), the price is close to $40k. For about $2k more you could get a HS250h. You'll sacrifice some MPG but you get a LOT more car.
    You can get a stripped down version of the CT for about $30k. But it's a Lexus and the great majority of people buying a Lexus will want typical Lexus trim which means the highest level trim package in the CT. I think they screwed the pooch on the CT and I don't think they'll sell many of them. I know I would definitely pay $2k more for a loaded HS than a loaded CT.
  18. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    I don't understand how anyone driving the CT cannot be impressed by the seats, great driving position, and the better ride, and fail to acknowledge those, given that those are its main distinguishing features from a Prius. At this point, the only thing standing between me and the CT is an earthquake and the lack of a plug in version. Therefore, I'm finding some of the reactions to the CT puzzling. Even more puzzling than the bad mouthing of the hybrids of other car companies. That prompted me to think about the past history of Prius. With apologies for post length, here's my take on that history, as a non-gearhead but tech oriented average car buyer.
    From the beginning, the 2 major questions about the Prius have always been (1) yeah, yeah, thats all great, but how much more am I going to have to pay for it than a regular car, and (2) what kind of compromises am I going to have to make in terms of drivability and comfort (I'll ignore the do I have to plug it in question).
    2002 (my first test drive) - Version 1 or 1.5. Critics called it a really expensive, unattractive version of a Corolla compact sedan. Seemed good enough to me, and bland but not ugly. Definitely an economy car look and feel though. No gov't incentives then, and couldn't get a reasonable lease. Version 2 was on the way, so I waited.
    2004 - Version 2. Totally unique car. Great mileage and great interior design that felt near midsize on the inside, even though it was compact on the outside. Absolutely great tech at a a relatively cheap price, that was not available on any other similarly priced cars at the time and made up for the so-called hybrid premium. Comfort seemed good enough for an economy car, which is what it still looked and felt like, other than the great tech. I was not crazy about the looks and my wife asked me "why'd they have to make it so dorky looking?" With the gov't incentive, there was not much, if an, hybrid premium. I really enjoyed it, but the highway handling and seats were awful. Taking it on long trips was uncomfortable and tiring. In short, there were in fact a lot of compromises you had to make to drive this car. Traded for Camry Hybrid in 2007 and waited for Gen III.
    2010 - Version 3. Yeah! Much sportier looks while still maintaining the same basic shape. Real car seats that are bearable over long distances. Can actually drive in a straight line on the highway, even in cross winds, without having to work too hard. If you have the Five, you get smooth and tight steering. 1,000% better for long trips. Humungous rear legroom and they fixed the lack of rear headroom. Despite being more roomy, they made it feel more compact in the front, by adding the bridged console. I was a defender at first, but would now call that a major design mistake. All in all, feels like a real car now, rather than an econo box, with very few compromises in comfort and handling.
    However, the seats are not very adjustable, and they didn't position the steering wheel close enough to the driver. If you raise the seat, you lose the bucket effect, since there's no way to raise the front portion. The seat bottom is not well padded and the adjustable lumbar support is OK but not great (feels awkwardly arranged, at least for my average body type). Even though the wheel now telescopes as much as other steering wheels from Toyota, there is no way to get it close enough to be truly comfortable. Also, they put the lower arms of the steering wheel in exactly the wrong place to be comfortable when resting your hands in the lower holding positions. Finally, and most importantly, the ride still sucks. I understand and appreciate why they don't use better, but heavier, suspension components, but that doesn't mean I have to like it. Admittedly, the low profile tires on the Five may make this problem a little worse, but they also contribute a lot to the improved highway stability.
    In short, there is still a huge difference in comfort between my Camry and my Prius, so there is in fact still a large compromise being made anytime I choose to drive the Prius over the Camry. Despite the 10 MPG difference, I would always choose the Camry for a long trip. Because I've grown increasingly weary of the vibrations and jars I get driving on bad inner city streets, I was very interested in seeing how well the CT would succeed in softening the ride, without sacrificing the improved handling.
    CT - My first test drive was a revelation. Those seats are fantastic (and yes, they have good lumbar support). The vibrations have largely been eliminated. The ride is still a bit firm and bumpy, but I don't see how you can have the low profile tires and sharper handling without at least a little sacrifice in ride softness. Perhaps the gearheads, or people who have driven more and better cars than I have, can enlighten me. Just as importantly, the low center of gravity in this car just feels better. Both you and the car feel absolutely planted while driving, there is no sense at all that either you or the car are being flung about. Even my wife, who didn't like the compactness of the CT, very much appreciated the seats and the planted ride feel. It also solves various other small issues I have with my American Prius, by adding things like dual zone AC, hdd nav with better screen, fully automatic headlights, and daytime running lights. Personally, I also felt the outside mirrors and rear visibility were also much better.
    The only drawback is that CT is a compact, and feels like it in front, unlike the Prius. They may have made a mistake by having such a wide console. It is interesting that the CT is the same width as the Prius but feels so compact side to side. I suspect the lowering of the driver position may have a lot to do with this. However, the CT is by no means claustrophobic. And if you don't need that extra room in back then you won't miss the cargo space. In short, other than compactness, which some people don't care about and may even prefer, what's not to like about the CT compared to the Prius? CT is very successful at what it was trying to do, i.e., make a compact luxury hybrid with near Prius MPG and the least amount of compromise to luxury that we have yet seen on a small, hatchback hybrid.
    3 people like this.
  19. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Yes, the CT can be had with lots of Lexus extras like rain sensing wipers, memory driving seat positions (passenger seat not as adjustable though), auto tilting and heated outside mirrors, and the fancy stitched leather dash and steering wheel. You can also get Prius extras like PCS and LED headlights (but good luck finding any model, let alone a fully loaded one).
    The HS250 is definitely not a better car than the CT, other than size. And it is a sedan. And by most people's opinions, kind of ugly or at best exceedingly plain (especially compared to an is250). Dash is also kind of ugly. Ride and handling are not at all impressive. I'd pick the much better value hycam over the poor seling HS250 every time. Yes, CT is slightly underpowered, but no more so than the Prius.
    Predictions about CT not selling well are kind of silly now that it is completely sold out and there are waiting lists. Some of that is earthquake related, but there is no doubt that CT is a hit and selling far better than Lexus hoped for, both here and in Europe. This is in part due to gas prices, but mostly because they did a great job designing it and hitting their target audience.
  20. Thai
    Thai Prius Neophyte
    1,197
    89
    This is what i wrote 2.5 months ago:
