Prius 2011 1.8 orange triangle with exclamation mark icon
Discussion in 'Gen 3 Prius Main Forum' started by Rehan1113, Jun 13, 2016.
  1. Rehan1113
    Rehan1113 New Member
    Pakistan
    I have 2011 prius 1800cc..my car dashboard display come ORANGE TRIANGLE WITH EXCLAMATION MARK light and msg HYBRID SYSTEM CHECK. ..car is start no problem in drive..every thing work. .but display computer (check consumption graph Charging wheel etc)not show...when i press staring display button show charging graph consumption etc only for few seconds.and go to msg check hybrid system. .please guide me what is problem...(sorry for my bad english)plz reply as soon ..thanks
    49,384
    i'm thinking inverter troubles.
  3. BZzap!
    BZzap! Senior Member
    1,607
    877
    That indicator display is alerting you to a serious malfunction which should be diagnosed immediately. I would not attempt to drive the car.
  4. Tbkilb01
    Tbkilb01 Active Member
    215
    187
    Louisiana
    Same symptoms...what was the problem?
  5. Tbkilb01
    215
    187
    Louisiana
    This happened to me and I drove 13 miles back home, ..prius made it and I reset via battery ground. Inverter circulates and ice responds along with charging of traction battery.
    #5 Tbkilb01, Aug 11, 2016
  6. bisco
    49,384
    read the trouble codes.
  7. Tbkilb01
    215
    187
    Louisiana
    P0A80 via ELM 327. Reset codes and has not shown again, cross my fingers (as if that will help)
  8. bisco
    49,384
    all the best!(y)
  9. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,801
    1,170
    Auburdale FL
    So what does the squiggly line mean with the triangle and ! point ?
  10. slewinson
    slewinson Junior Member
    36
    30
    Australia
    It is a message in ancient Chinese...
    Loosely translated it is Sum Ting Wong
    Simon
  11. Piotrus Pan
    Piotrus Pan Member
    126
    46
    Luxembourg
    Dear god I loughed so hard that I started crying!
  12. Johnspu
    Johnspu Junior Member
    Michigan
    Several months ago I had a full service oil change on my 2011 at Walmart. This warning was on when they were done, and as they were attempting to figure it out the car completely died. I had it towed from Walmart to the Toyota dealer, and $114 later was told the airbox was not hooked back up correctly (Walmart checked the air filter). They hooked everything up and recharged the battery and all is well. No idea what the airbox has to do with the hybrid system. Btw Walmart did reimburse me.
  13. Piotrus Pan
    Piotrus Pan Member
    126
    46
    Luxembourg
    You mean the part where the air intake is? With air filter?
  14. Bham_prius
    Bham_prius Junior Member
    35
    bellingham
    That is why I never have someone else change my oil and if I have to I tell them just change the oil don't touch anything else.
    Playtimenick likes this.
