Prius 2011 does not start
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by selg81, Feb 23, 2015.
  1. selg81
    selg81 Junior Member
    toronto
    Yellow triangle lighting up together with check engine light,
    Also when turning it on display says to press brake and push power to start,
    Speedometer is not lighting on at all.
    There is no stop light - turn lights - parking lights, cannot operate the windows, lock/unlock doors but it beeps when operating remote
    This is what works:
    Emergency flashers, lo/hi beam, detection of door open, power button changes colors,
    Anybody has any idea what component are affected
    #1 selg81, Feb 23, 2015
  2. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    The best place to start is the 12 V battery.
    Assuming you can open the rear hatch, remove the flooring around the passenger rear side of the cargo area to gain access.
    Try disconnecting the ground (black wire) clamp from the battery post for a minute and reconnect it.
    If this doesn't accomplish anything, connect jumper cables from another car very carefully as you would for any jumper start. BE ABSOLUTELY SURE THAT YOU CONNECT THE CABLES CORRECTLY, POSITIVE-TO-POSITIVE, ETC. as you could seriously damage your car if you do it wrong.
    There's no need to even start the other car if its battery is good (and it's safer if you don't introduce that noise to the boost voltage) as you're not using it to actually crank your Prius.
    Let us know if this gets you going.
    49,379
    if it's not that, check the fuses. an also, make sure your brake light switch is making contact. have someone look at your lights while you step on the brake to power up the car.
  4. tv4fish
    tv4fish Member
    202
    46
    While I agree with that -- I think the very first thing I would do is check your existing 12 volt battery and your existing battery connections (cables). If you have a multi-meter - check the voltage of your existing battery to make sure it isn't dead.
  5. robray
    robray Junior Member
    I just replaced my battery yesterday with one from the local parts store here in Vancouver. It is ACDelco brand part number ACDB24R. It was $164 + tax with my discount. Original quote was $210. My car is a 2010, but I would have thought the battery would last longer. My friend gave me a ride to pick up the battery and his 2001 Civic is still on the original battery.
  6. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    You need to update your avatar as it says your car is a 2004.
    The OEM battery only has a 4-5 year expectancy. My 2010 battery died a couple of months ago.
    Is the Delco battery Lead Acid or AGM? Since the battery is in the cabin with you any battery venting is inside the cabin unless it has a vent tube to vent outside of the car.
    Was the $210 quote from a Toyota dealer? If so this was the correct battery for your car, an AGM with vent tube. The replacement battery has a 84 month warranty.
    #6 jdcollins5, Mar 23, 2015
  7. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    Your friend's claim is hard to believe.
    What apparently shortens the life of Prius 12V batteries is their low capacity and the car's low level continuous current draw while waiting for an SKS fob to happen by.
