Prius 2013 goes into ready mode but engine won't start. key fob is still working
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sarah Burgart, Jul 4, 2019.
  1. Sarah Burgart
    Sarah Burgart New Member
    Seattle, WA
    Ive checked all the suggestions I have found on the forum so far, and elsewhere. Brake lights and key fob are both still working, lights are normal brightness.
    What isn't working: If I depress the brake pedal fully and press the Start battery the light turns green on the start button. When I remove my foot from the brake pedal, light turns amber.
    If I try to shift to another gear while brake pedal is depressed it won't shift, and it doesn't sound like the engine is actually turned out, just hypothetically ready to do so.
    Any hints/ help / troubleshooting suggestions would be appreciated.
    I could try and find a jumpstart, but I am thinking that since the lights aren't dim and the key fob is still working it probably isn't the battery?
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Check your 12v battery
    51,155
    you say that it goes into ready mode. if correct, you don't need a jump and your 12v is fine.
    does the 'ready' light up?
  4. Sarah Burgart
    Seattle, WA
    I'm sorry, I don't understand what you mean by 'the 'ready''
    The Start button turns green when I press it with my foot on the brake, if I take my foot off, instead of doing the usual, continue to run, it turns amber
  5. Sarah Burgart
    Seattle, WA
    Based on what, please? I have none of the signs I have read about
  6. bisco
    51,155
    your title says 'prius 2013 goes into ready mode'.
    but ready mode is the actual word lit up on the dash.
    the fact that it is not going into ready mode usually means your 12v is low/dead.
  7. Sarah Burgart
    Seattle, WA
    oh geez. I was conflating the green light with the full Ready Mode. thank you. I will acquire a voltmeter (as I am guessing jumping a good battery is not a recommended course of action)
  8. bisco
    51,155
    jumping a good battery is fine. it will tell you whether it is the battery, or something else.
    you can also pull it out and take it to an auto parts store for testing. how old is it?
  9. bisco
    51,155
    also, make sure the brake lights come on when you press the pedal. there have been many reports of incorrectly adjusted or bad brake switches, and it is part of the starting circuit.
    CR94 likes this.
  10. Sarah Burgart
    Seattle, WA
    As far as I know, it's original, and the car has ~80k miles on it. I have not changed it at least since I got it with ~50k miles.
    Yes, the brake lights come on.
  11. Sarah Burgart
    Seattle, WA
    I have a battery tester arriving today
  12. bisco
    51,155
    excellent. now, we wait
  13. Sarah Burgart
    Seattle, WA
    Battery tester says the battery is dead. Now to choose a new one! Any suggestions?
  14. Rebound
    Rebound Senior Member
    3,972
    2,627
    Portland, OR
    The Optima Yellow S46B24R is a good choice. I’d just see what they have at your local auto parts store. Most auto parts stores will help you install it right in the parking lot, as long as they aren’t too busy.
    Because the battery is inside the car, there is a tube used to vent hydrogen gas outside. Be sure that tube is connected when the new battery is installed. Hydrogen gas is flammable (remember the Hindenburg?), and venting the gas prevents the possibility of the hydrogen igniting in your car (which isn’t very likely, but...)
    The Prius 12V battery is somewhat unique: It’s not used for turning the starter motor, and it’s charged from the Big Battery. All it does is “boot up” the electrical system. That’s why these batteries are so small and long-lasting. The only problem, really, is that with traditional car batteries, you can tell when they’re dead because you either get no electricity at all, or the engine turns slowly but doesn’t start. The Prius doesn’t give you any clue that it’s the battery. Don’t bother with an extended warranty or anything silly.
    Ed Beaty likes this.
  15. Sarah Burgart
    Seattle, WA
    Yeah, now the problem is just getting the car to the auto parts store ... Hoping it can get there with a jump
    And thanks!
  16. bisco
    51,155
    i like the oem. after that, there are a few options, none of which i would say are unworthy
    AzWxGuy, scona and jerrymildred like this.
  17. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    I'm also a big fan of the OEM battery. Something kind of appealing with that 84 month warranty. ;)
    AzWxGuy and scona like this.
  18. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    My $65 AGM is still behaving well after 53 months, despite occasional inadvertent abuse.
  19. tankyuong
    1,555
    661
    Central MO
    Is that the scooter battery?
  20. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    U1 size, which is used for numerous purposes, including mobility devices. Not difficult to adapt to Prius, including venting.
    tankyuong likes this.
