prius 2013 traction control lights remains on
Discussion in 'Gen 3 Prius Main Forum' started by IDs mak, Sep 6, 2021.
  1. IDs mak
    IDs mak Junior Member
    31
    Ny
    My Prius with 114k miles. Has been parked for past few month. I keep rolling it for 10 minutes every week to keep the battery functions going. .
    I noticed the traction control light has been on.
    No other lights on dash. Drives just fine
    Is there any fuse or relay that I can check.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    10 minutes a week is not enough.
    Your 12 V battery may be getting weak.
    Need to "pull the codes" to get a better idea.
    49,417
    not that i know of, might be a bad speed sensor, or corrosion on the connections
  4. ASRDogman
    ASRDogman Senior Member
    6,077
    3,270
    Put a 4 amp or less charger on the 12v battery overnight. Make sure it's fully charged.
    Get a code ready that will also read the ABS system.
    And see what code you get. Maybe charging up the 12v battery will resolve your problem.
    10 minutes a week is just wasting your time. DRIVE the car for 30 minutes every week.
    Having a car sit is not good for any car.
  5. ChapmanF
    15,537
    Or if you don't have such a reader (I think 'ready' was meant to be 'reader'), you can use a short skinny jumper wire and get your brake and traction codes by counting light blinks. It is often handy to know how to do that, because it is easy to have warning lights come on when you don't have a code reader with you, and for systems like your brakes, it is good not to have to put off finding out what the trouble codes are.
