Prius 2014 Plugin - OBD2 P0300 - Random Misfire
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by apt5020, Mar 26, 2015.
  1. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    I hookup an OBD2 tester on my Prius 2014 Plugin and saw the OBD2 P0300 - Random Misfire. I did a reset and the error still came on. I also tested my friend Prius 2014 Plugin which is factory stock and had the same error. Wonder if that is by design or not. Going to take my ride into the dealer on Friday for my 25K maintenance and have them look into that error. P0300 can be anything. Hopefully doesn't cause more problems down the run
    OBD-II Trouble Code: P0300 Random/Multiple Cylinder Misfire Detected
    52,349
    nothing you could sense while driving?
  3. apt5020
    881
    1,294
    Prius City, CA
    Nope. My MPG still normal. I get around 55MPG. Ride normal. Test your if you can see any errors. It's under history stored
    52,349
    i wonder if it's something to do with the special valve timing?
