Prius 2015 blower not working
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by abidz05, Aug 14, 2022.
  1. abidz05
    abidz05 New Member
    US
    Hi All,
    I have a 2015 Toyota Prius with a blower motor that does not work. I took the blower motor out which has 3 pins connection negative, positive and one middle pin. I connected the blower to 12 V battery but it seems to be not working. I only connected the negative and positive, not sure about if the middle one is needed. I also checked the connection to the blower from the car and it seems that there is no power coming to it at all. Any idea how to diagnose this, or to start.
    Thanks
  2. PriusCamper
    PriusCamper Senior Member
    12,062
    4,894
    Pacific Northwest, USA
    Which blower motor? Itf it's the one for the hybrid battery you can use Hybrid Assistant app via a bluetooth OBD2 reader to power up the fan to confirm it works.
  3. abidz05
    abidz05 New Member
    US
    No this is the AC blower Motor
    51,148
    find the fuse and see if it blew. if not, check for voltage. if there's voltage, then you have awiting issue in between, or from the fan switch, or bad switch
  5. abidz05
    abidz05 New Member
    US
    I checked for fuses for this fan, but none seems to be there
  6. Elektroingenieur
    2,515
    3,277
    Three Touring
    In the Repair Manual (more info), see the topic Vehicle Interior: Heating/Air Conditioning: Air Conditioning System: Blower Motor Circuit.
    The third terminal (SI) on the connector is the blower motor speed control signal, and yes, it’s needed for the blower motor to run.
    It’s the HTR fuse, a 50 A fuse element in a 50 A/30 A/30 A fusible link (part number 90982-08300) in the engine compartment. In the Owner’s Manual (PDF), see “Checking and replacing fuses,” pp. 466–477; the HTR fuse is item ① in the illustration on page 469.
    PriusCamper likes this.
  7. ToyXW
    ToyXW Active Member
    153
    148
    Sacramento
    Turn it on high. If it doesn't come on, give the blower housing a good thump with your hand/fist and see if it comes on.
  8. nicoj36
    nicoj36 Active Member
    518
    162
    Just get new blower motor
  9. PriusCamper
    12,062
    4,894
    after you confirmed that's the source of the problem...
