Prius 2015 vs Prius 2016 Which One To Buy?
Discussion in 'Gen 4 Prius Main Forum' started by Deoc, Feb 21, 2024.
  1. Deoc
    Deoc Member
    70
    39
    Pasco
    2014 Prius Plug-in
    Without looking at the price difference, in terms of quality, gas milage, and realibility, which on would you choose?
  2. ETC(SS)
    6,555
    The G4 is more fuel efficient and somewhat more reliable, but it's as ugly as a mud fence to me, especially the back end.
    Subjective, I know but there's a REASON that they did an emergency refresh.
    Handling is somewhat improved over the G3
    Price and (accurate!) odometer reasons are the 2 largest determiner of whether you get fair deal and how reliable the car will wind up being.
    I would also want some data from the mothership about service history and any fender-benders or major accidents.
    You're talking about 8 and 9 year old cars.
    They're like middle aged humans.
    Some are remarkably fit.........................for their age.
    49,490
    16 all the way, from everything I’ve read here over the past 14 years, but do your due diligence on the exhaust heat exchanger issue
    Tande likes this.
  4. Deoc
    Deoc Member
    70
    39
    Pasco
    2014 Prius Plug-in
    I have the same problem as ETC the 2016 versions has some weird design but i wanted to know if there was a big difference and it seems like there is, at this point i love the design of the new prius generation and im still deciding if i should wait instead, but thank you some much already appreciate you guys opinion
  5. rjparker
    rjparker Tu Humilde Sirviente
    7,975
    4,716
    Texas Hill Country
    2016 Quality far better
    2016 mpg better
    2016 Reliability far better
    2015 Quality suffers with head gaskets, brake boosters and egr clogging
    which makes the
    2015 Reliabilty much worse
    So your 2016 total cost of ownership is sure to be less even if you pay $3500 more.
    Sorry if the above is too obvious for some…
  6. FuelMiser
    FuelMiser Senior Member
    1,300
    887
    Monument, CO
    If by "new prius generation" you mean the new Gen 5, then I suggest you try one on for size in person before going any further down the path of waiting. Yes, they look a lot better, but are significantly smaller/tighter on the inside, both front and rear cabins. I did and decided I could never be comfortable fitting in the new one.
