Prius 2017 electric package noise
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Matella, Feb 11, 2024.
  1. Matella
    Matella Junior Member
    Toronto
    Hello to everyone. I have a constant noise coming from the electrical package which is located on the driver's side. I went to several service and they told me not to worry, as it is normal. When I bought the car this noise did not exist. When it's cold this noise gets louder. Any ideas? Thank you
  2. AzWxGuy
    AzWxGuy Weather Guy
    1,071
    549
    Tucson, AZ
    2021 Prius
    IDK, maybe capacitor squeal. Some high-end juice monitoring goes on in the inverter case. It's not the pesky pedestrian notification system I take it. Prius has always made interesting noises, which are even more interesting when you know what is making them.
    Matella likes this.
  3. ChapmanF
    18,570
    Sometimes things that are known to vibrate at audible frequencies will be mounted with rubber grommets, or the like, to reduce the propagation of the sound into the rest of the car, and very cold weather makes the rubber harder.
    Matella likes this.
  4. Matella
    Toronto
    the noise comes from this part. Is there a reliable service where I can check it? I live in North York, Ontario..Thank you
  5. bisco
    52,405
    Inverter whine increases with cold, can you post a video?
  6. Matella
    Toronto
    I am trying to upload a video, but the site does not accept it, as the file is large
  7. Matella
    Toronto
    This is the message I get when I want to post the video
  8. Matella
    Toronto
    Here link
  9. bisco
    52,405
    thanks, all i hear is the engine
  10. Matella
    Toronto
    Apart from the noise of the engine, if you listen carefully, it is a subtle noise. I can compare it to the sound of a mosquito. You just have to listen carefully
  11. bisco
    52,405
    my hearing isn't very good. hopefully someone else will tune in.
  12. Matella
    Toronto
    I don't know why it is so hard to find a good Hybrid car technician in Toronto. Most of them do only the usual car services
  13. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Does it make the noise when the ICE off? All I hear is a very loud ICE, too loud IMO.
    A steady hum from the inverter is fine. Also, there's a separate cooling system for the inverter (the small coolant bottle in front) and that pump will also make a hum when operating.
    Matella likes this.
  14. Matella
    Toronto
    I'm new to this car and I don't understand some terms, but I wanted to know what is ICE and IMO? Thank you
  15. ColoradoBoo
    ColoradoBoo Senior Member
    1,273
    881
    Monument, Colorado USA
    ICE is Internal Combustion Engine. The big black box you have a picture of is your invertor. (In short, the hybrid inverter/converter is responsible for boosting the voltage from the DC hybrid battery from 200v to 500v in order to create the three phase power needed for MG1 (motor generator) and MG2. The inverter also supports voltage lowering conversion from the hybrid battery to the 12v system.)
    The Prius is a very complicated hybrid system which means it runs off electricity stored in the big battery under the rear seat in your car. It has an MG1 and an MG2 (motor generator) that drives the powertrain...the car doesn't actually drive from the ICE engine, that's used to give the car electricity and, also, the radiator heat is used to heat the car. The air conditioning is a high-tech electrical compressor, doesn't use the ICE engine at all (except for electricity), which is a very cool invention.
    A good resource for learning about your hybrid is The Car Care Nut on YouTube....he even has a video on the strange noises it makes (like when you open your driver's door.) You have a 2017 so I don't think you have the infamous "UFO" speaker which is just a speaker on the front of the car that turns on when you drive slow or are backing up....the new RAV-4 hybrids have a very loud UFO speaker, I can hear my neighbors from my garage when he drives down the street.
    Because of all the electrical components folks who don't drive the car a lot have a lot of problems because it wants to recharge the batteries often. I've found even letting the car sit for a week makes the 12-volt battery low.
    Matella likes this.
  16. Mendel Leisk
    41,928
    And "IMO" is "In My Opinion".
    Have you tried Toyota dealership service departments?
    Dealerships? They may be right? Not hearing anything unusual in the video you posted. To be fair it may be hard to capture the sound you're hearing.
    How long have you had it?
  17. bisco
    52,405
    there are few qualified hybrid mechs anywhere because they are so busy with gassers it isn't worth their time
    Matella likes this.
  18. ChapmanF
    18,570
    and, to the OP's question, the inverter circuitry does that by switching electric currents on and off several thousand times a second to create waves of the right voltage and shape. (There's an old post that's about a different kind of inverter, for making 60Hz household power, with some pictures of how that wave-shaping by rapid switching works, for anyone interested in those details.)
    Anyway, when those electric currents are rapidly switched on and off, so also are the magnetic fields that go with them, and those will slightly wiggle any of the magnetic metal in the area, at the same several-thousand-times-a-second frequency. Those vibrations are sounds in a range a person can hear, a subtle noise you can compare to the sound of a mosquito. Just what it does.
    Matella likes this.
  19. FuelMiser
    1,349
    929
    Monument, CO
    Boo, that's complete BS. The ICE definitely drives the wheels through the Hybrid Synergy Drive. I suggest you review Hybrid Synergy Drive - Wikipedia
    Now, there were cars, not Toyota, that used an ICE to run a generator that powered the car, but Toyota's HSD
    Harters likes this.
  20. Matella
    Toronto
    Thank you all for the explanations. Now I need to find a reliable hybrid car technician in Toronto. It will probably take me a long time to find it
    Danno5060 likes this.
