Prius 2024 purchase: Electric System Questions
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by pgb205, Feb 25, 2024.
  1. pgb205
    pgb205 New Member
    earth
    How many 12 volt (cigarette) ports does the car have and what is the output wattage?.
    • Seems like only one, but still need info on the output
    Can I power from prius when it's off.
    • Apparently it has the same 'Accessory mode' as regular cars. But otherwise the engine needs to be on to use things like inverter.
    usb-c ports: Are they pd capable or not?
    • 15 Watt output so apparently not PD. I assume that it's 15W per port not total?
    If anyone has more information on these, partially answered questions, please do let me know.
    thank you
  2. Paul Gregory
    Paul Gregory Active Member
    399
    112
    Alberta
    2024 Prius Prime
    XSE
    I thought I saw somewhere that it had a 20 amp rating, which would be 240 watts,
    but don't take this for gospel.
