Prius 3 where is the sightlight cable in the interior???
Discussion in 'Gen 3 Prius Audio and Electronics' started by Prius_germany, Jul 12, 2017.
  1. Prius_germany
    Prius_germany New Member
    Germany
    hello,
    i need you help again =)
    i was looking for the sidelight cable in the interior... i need the signal for something other... but i can't find it under the dash =(... i don't want to take a wire from the outside...
    so where can i found the correct wire?!
    my car is a 2010 prius 3 without led headlights
    thanks a lot!
    greetnings from germany =)
  2. Prius_germany
    Germany
    no one can help me?! =(
  3. Prodigyplace
    12,407
    11,682
    Central Virginia
  4. 4md
    4md Member
    97
    55
    Sofia, BG
    you can find it under the steering wheel where the module with the 3 white connectors (2 big, 1 small) is. The side (parking) lights are the brown wire at the bottom connector at the first pin top to bottom at the right side.
  5. NavyLCDR
    NavyLCDR Active Member
    201
    125
    Lebanon, OR
    2024 Prius
    XLE AWD-e
