Prius 3rd Gen V Auris Hybrid
Discussion in 'Gen 3 Prius Main Forum' started by Prius Fleet Owner, Mar 26, 2018.
  1. Prius Fleet Owner
    Prius Fleet Owner Junior Member
    22
    Plymouth
    Active
    Hello all.
    Anyone know if there is any difference when comparing the Auris versus the 3rd Gen Prius?
    I am referring to the oil burning issue and head gasket specifically that seems to be common on the 3rd Gen Prius.
    Does the Auris suffer the same fate?
  2. m.wynn
    m.wynn Senior Member
    684
    1,229
    Queensbury, NY
    I don't know which model years apply, but it appears some Auris hybrids do use the afflicted 1.8L engine. Here's a pic from Eurekar.co.uk. If this is what your engine bay looks like, it would be my opinion that following the EGR circuit cleaning protocol generally outlined here on Priuschat would be smart money. Oil catch cans have developed a following, too. A final (and strictly personal) thought is that a 5k mile oil change protocol is good insurance against oil burning taking hold. If the U.K. follows European style, long oil change intervals, use a high quality A3/B4 or other high HTHS full synthetic.
    http://cdn.eurekar.co.uk/uploads/images/large/aurishybridengine.jpg
    #2 m.wynn, Mar 26, 2018
    Mendel Leisk and Raytheeagle like this.
  3. Prius Fleet Owner
    22
    Plymouth
    Active
    Yes.
    Think I will avoid buying.
    Gonna have to skip that era of Toyota hybrids and go straight from 2016 onwards.
  4. Prius Fleet Owner
    22
    Plymouth
    Active
    Do you know if the Lexus CT 200h suffers the same issue?
    It seems it uses the same 1.8 litre engine.
  5. Grit
    Grit Senior Member
    6,450
    4,186
    Wilkes Land
    Skip Toyota, Honda hybrids are the way to go now.
  6. Prius Fleet Owner
    22
    Plymouth
    Active
    You got a Honda hybrid?
  7. m.wynn
    684
    1,229
    Queensbury, NY
    Likely a wise choice. Toyota has re-designed the EGR circuit for 2016 and newer, placing the all-new appearing EGR cooler downstream of the cat. In theory, this should at least improve the tendency for circuit clogging, if not fix it completely. It will take years and miles for us to know this is the outcome for sure, though...
    Yes it does, and is well documented, too. Any Toyota hybrid running this iteration (2010-2015) of the 2ZR-FXE engine with external EGR is affected. Note that the 2016 and newer prius engine is still called 2ZR-FXE despite EGR re-design.
    Toyota ZR engine - Wikipedia
  8. Tideland Prius
    16,445
    lol. Since when?
    m.wynn likes this.
