Prius 4 120V outlet
Discussion in 'Gen 4 Prius Main Forum' started by Victorio Mo, Sep 24, 2021.
Tags:
  1. Victorio Mo
    Victorio Mo Member
    111
    29
    Folsom, California
    I just found out that there is 120V outlet in my Prius, is there any lighter to US plug adapter for this model, tried to find and could not, anybody has experience using it?
    I'm trying ot use my 120V laptop power brick with it.
    Thanks
    M
  2. fuzzy1
    10,254
    Could you have misread a label that says 120W, not 120V?
    The "lighter" outlet is 12V, 10A, which equals 120 Watts, not Volts.
    PaulDM, amos, xliderider and 2 others like this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    Are you talking about your 2008 PRIUS - the Gen 4 (which is where this post is) hasn't got one - at least here.
  4. FuelMiser
    FuelMiser Senior Member
    1,303
    890
    Monument, CO
    What you need is an inverter that plugs into your 12V DC and gives you 120V AC.
    xliderider and alanclarkeau like this.
  5. jerrymildred
    jerrymildred Senior Member
    11,518
    14,124
    Tampa, FL
    I think you mean this: (from a Gen 2 manual. If you actually have a Gen 4, the location is different.)
    There is no 120V outlet in any Prius, although I've read that in Japan, at least some models of the Prime have a 100V outlet.
    As @fuzzy1 and the owners manual both indicate, those outlets are 12V, not 120V and are limited to 10A. Just get an inverter as mentioned by @FuelMiser and you'll be good to go as long as you stay within the power limits described in the manual.
    PS. There's an error in the manual. Notice that is says the car must be in ACC or IG-On to use the outlets. They also work in READY mode as one would expect and, in fact, that's the only way to use them if you want to be sure to not drain your 12V battery.
    PaulDM, fuzzy1 and alanclarkeau like this.
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,790
    2017 Prius c
    Contact a computer store or three and see if you can get a compatible 12 V "brick" to use when in the car.
    Or contact your computer maker directly.......if that is even possible.
    As was explained above, if your laptop requires more that 120 watts to run, you might be out of luck.
  7. jdenenberg
    jdenenberg EE Professor
    3,859
    1,858
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I've used a 100W inverter in my cars to power a laptop via it's 120VAC power brick so it can be done. As others have said, a somewhat better option is to use a 12VDC computer power supply if you can get one. A third, and even better option if your laptop can be powered via a USBc cable (many newer ones can use USBc power), would be to buy a high power USBc power supply Like this one at Amazon:
    120W USB C Car Fast Charger - Dual Ports PPS PD 100W Type C Super Fast Charging + QC3.0 20W Cigarette Lighter USB Adapter for Laptop Tablet MacBook iPad iPhone Android Switch Pixel
    Price: $35.99 & FREE Returns
    that plugs into the 12VDC auxiliary power plug (AKA "Cigarette Lighter") and use a USBc cable to power your laptop.
    JeffD
    #7 jdenenberg, Sep 24, 2021
  8. bisco
    49,698
    you could put an outlet on this:
    ref=sr_1_17_sspa
  9. Victorio Mo
    Victorio Mo Member
    111
    29
    Folsom, California
    Thanks all guys,
    it's not about 12V /inverters, in my 2016 Touing Prius I have 1 outlet (cigarrete lighter Female type) marked 120V AC (Volt) and it's factory made.
    So look like you just need that type of male, I will snap a photo to show exactly how it looks like. I will try to do Y split on my power brick. .
    Tx
    #9 Victorio Mo, Sep 24, 2021
    Mambo Dave likes this.
  10. ChapmanF
    15,865
    Yes, please snap a photo.
    That sounds like it would violate more or less every electrical safety code imaginable .... :cautious:
    fuzzy1 likes this.
  11. Salamander_King
    Salamander_King Senior Member
    10,975
    8,873
    New England
    Never heard of a cigarette lighter 120V AC (Volt) outlet in any cars. Our Pathfinder has 120v outlets but it is a regular NEMA 5-15R receptacle. If you have a multimeter it would be easy to test if it is really supplying 120V AC or not.
    The photo below is from our Pathfinder. The right two panels are regular cigarette lighter plug 12V open and closed. The left panes show the special 120v AC outlet on the center console with NEMA 5-15R.
  12. jerrymildred
    11,518
    14,124
    Tampa, FL
    Well don't poke your finger in there. It may kill you. And for sure don't let a kid do that. I'm 99.999999999999999999999+% sure that you misread it and it is 12V. No car ever came with 120V "cigarette lighter" style outlet. What a humongous safety hazard. NHSTA would never allow it.
    fuzzy1 and Salamander_King like this.
  13. sam spade 2
    7,035
    2,790
    2017 Prius c
    Nope. Not possible.
    Unless a previous owner screwed with it.
    That type of outlet NEVER is used to supply 120VAC.
    NEVER.
    You have a misunderstanding somewhere.
    Maybe there is an actual 120V outlet above or below that label.......which is fed by a built-in 12 V inverter.
  14. fuzzy1
    10,254
    Yes, please show us some photos. Built-in 120VAC is an option that very many of us have long wanted, since well before 2016, but just haven't seen on any North American Prius. So far, we are aware of only 100VAC on some Japan Domestic Market units.
    jerrymildred likes this.
  15. bisco
    49,698
    sounds more like a cigar lighter
  16. Victorio Mo
    Victorio Mo Member
    111
    29
    Folsom, California
    Thansk Salamader and sorry to all, I made a mistake, it's 120W not volts, so it's 12V line, it was too dark when I looked at it.
    Case closed.)
    fuzzy1, bisco and Salamander_King like this.
  17. ChapmanF
    15,865
    Thanks for the follow-up. (y)
    alanclarkeau and Salamander_King like this.
  18. fuzzy1
    10,254
    Yes, thanks very much for the followup. Too many things like this end in silence as the OP disappears, so that we don't know if we produced a correct answer, or if there were certain other cases that none of us knew or remembered.
