Prius 4 coolant bypass valve removal
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by AlexKamal, Mar 24, 2025.
  1. AlexKamal
    AlexKamal New Member
    United Kingdom
    Excel
    Hello all.
    Prius 4, 2016, 75k miles, UK model.
    Recently I had a common problem with white cloud from exhaust, so instead making a bypass I decided to invest in new cat converter. No problems with availability. Cost for cat and 2 gaskets: £1266 VAT included.
    Really easy job, the main problem was to lift the car high enough, but managed to do it.
    Problem solved, but I decided to scan for errors using vgate plug and CarScanner. Got a P2681(72) error - coolant bypass valve stuck open.
    Happy to change the valve, but it seems the job isn't so easy like with catalytic converter.
    QUESTION:
    Could anybody point me how to remove this little bastard as for me it seems that I have to remove inverter to get access to this valve.
    Thanks for any help in advance.
  2. AlexKamal
    United Kingdom
    Excel
    Update - still no info how to do it, but got another error P2681(9C)
    @AdeelUK help, you are probably the only guy who know how to dismantle this bastard...
  3. ChapmanF
    17,326
    Those of us in the US don't even have that little bastard (except for some people who have swapped their engines for imported ones and posted in puzzling threads about it).
  4. AlexKamal
    United Kingdom
    Excel
    Lucky you all
    That's the reason why I'm trying to get involved @AdeelUK
  5. Danno5060
    Danno5060 Active Member
    357
    182
    Wyoming
    Can you get at it if you remove the EGR Valve?
    AlexKamal likes this.
  6. AlexKamal
    United Kingdom
    Excel
    Don't know yet, but it was my idea for weekend job, just waiting for that valve delivery. It seems that removing EGR could be easier than messing around the inverter...
    Thanks anyway.
