Prius A/C Cycle Question
Discussion in 'Gen 3 Prius Main Forum' started by Jordan M., Jun 19, 2012.
  1. Jordan M.
    Jordan M. Jamman85
    Hi Everyone,
    New 2012 Prius Four owner here with a question: I've had my Prius for exactly one week and I noticed something peculiar the other day and I am wondering if it is normal. When I sit with the car on (in ready mode), in park, with the air conditioning running I hear a cycling noise coming from the engine compartment. The noise seems to cycle on for 5-10 seconds and then you hear a whirring down as it cycles off. A few seconds later it will come on again and thus goes the cycle. It's almost like a pulsing. If you roll down the window, you can hear it more clearly from the outside: the cycling on and off of what I am thinking is the A/C compressor. The airconditioning continues to blow at a constant speed and temperature and I don't get the sense that anything is actually wrong. The frequency of the cycling is what concerned me originally as it seems like whatever is going on is pulsing on and off at a relatively fast cycle (10-15 seconds total). Perhaps this is totally normal and just a function of the variable speed compressor and I just never noticed it because I've always had the radio on etc. while sitting in park/idle with the air conditioning on. I've been searching around for an explanation of this but haven't been able to find anything so I'd love some input. I'm hoping this is just one of those Prius noises that as a new owner I am just not familiar with yet. Thanks in advance!
  2. Jordan M.
    Jordan M. Jamman85
    I should also mention that I hear the noise both when I first start the car and am just sitting in the garage for a few minutes or after driving for up to an hour or so. In all cases, the ICE appears to be off, with the A/C running off the battery. Thanks!
  3. markabele
    5,084
    1,782
    Nebraska
    You are right. It is the air conditioner cycling. It doesn't need to run all the time when it's not too hot out and if you don't have it set too low. Keep in mind that the fan speed is totally independent of what the AC is doing. In other words the fan will stay constant even thought the AC is cycling.
  4. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    That's the genius design of Prius A/C. The compressor only runs at set temperature and stop when cabin temp. is right to the setting. Runs again when cabin temp. rises. Speed is control by computer. And on and off....... Never like conventional A/C,always runs at max cold and then use hot engine collent running around the coil to lower to the set temp.,if not set at max. cold. Wasting energy. Never match Prius design. Compressor of Prius last much longer. Enjoy.
  5. Jordan M.
    Jordan M. Jamman85
    Thanks very much for the replies, I really appreciate it! LOVE my new car!
  6. yeldogt
    yeldogt Active Member
    810
    313
    NE
    I'm not sure if the compressor in the Prius is variable speed - but all auto systems cycle to maintain the evaporator temperature. Many of the newer systems have variable capacity systems that can actually vary output at the same RPM. The special thing about the ePrius is that it is electric -- so the engine does not need to be running. Modern auto AC systems are very efficient. I will admit the Prius compressor does have a strange sound.
  7. NiHaoMike
    NiHaoMike Member
    98
    16
    Pretty much every hybrid nowadays has a variable speed compressor. Note that the Prius has an oddball "ejector cycle" A/C that needs a relatively high minimum speed to operate properly, hence the cycling at low load.
    And while it's possible to build compressors that have variable capacity at one RPM (Copeland's Digital Scroll being the most notable), it's mostly obsolete since variable speed is so easy to implement nowadays. It's a lot cheaper to add in a motor control DSP than it is to implement a variable speed drive mechanically. Even cheap computer fans have variable speed motors nowadays.
    HTMLSpinnr likes this.
  8. alekska
    alekska Active Member
    435
    138
    Atl
    I'm pretty sure the compressor is variable speed on my 2005.
    - Alex
  9. milkman44
    milkman44 Active Member
    591
    386
    Ky
    Setting with car in "ready" and the AC on, from the outside, the only thing I can hear cycling is the cooling fan blowing air across the condenser. Maybe the compressor is running at the same time, but I don't hear that.
  10. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    The Prius A/C compressor has been variable speed since the 2004 MY. Variable does have finite steps though, and watching with a Ccangauge, the steps seem to be in 50 watt intervals from 350w up to 1800w.
    Well, technically all car A/C compressors are variable speed - most were just tied to engine RPM and would cycle accordingly. The Prius (and any other hybrid or electric that uses similar technology) uses a variable-speed electric compressor that is *not* tied to engine RPM. The compressors require enough power input that running them off of 12 volts would be a prohibitive amp draw for most car systems (150A at 12V for 1800w, or almost 129A at 14V).
  11. yeldogt
    810
    313
    NE
    I should have said variable output capacity at a given speed -- Many do not actually use the electric clutch unless they have a problem or you turn the system off -- the compressor is always on. I assumed that the capacity was controlled by the speed of the motor -- as in the inverter mini split systems.
  12. NiHaoMike
    NiHaoMike Member
    98
    16
    Most A/C systems do cycle the compressor to vary the capacity, even almost all variable speed ones if the demand is low enough. The Copeland Digital Scroll as well as the (long obsolete) Brysch unloading compressor are designed to cycle much faster. The Digital Scroll uses hydraulics to separate the scrolls so they do no work, and the Brysch uses a solenoid to hold the suction valve open.
  13. lech auto air conditionin
    830
    601
    261
    san francisco
    It sounds a little LOUD? unless you are in a vary quite place and have good ears. Yes some can have a little more noise then others. I have comes across a few 2010 that already needed a recharge, mostly taxis with over 150000 miles on them and had front end hit and a body shop ether did not replace a damaged condenser just straightened it and put it back in and it leaked later. The other is your insurance company told the body shop to use a cheaper part, not Toyota's. Some times they leak with in a year or it was never recharged correctly and you will hear this sound a little louder then normal. Pruis electric compressor do not like low or over charged refrigerant. It's death to them...
  14. lech auto air conditionin
    830
    601
    261
    san francisco
    but on a 2012 may be normal. here in San Francisco its usually not that quiet to hear it. Did you buy your 2012 new ? or used? I have all ready came across a few that had front end damage and had the condenser replaced and after the A/C was recharged at a shop it would make noise. The new owners did not know, and ether the shop was still using and old air conditioning recharge that are not accurate for the small charge of the new cars and not be used on the newer cars of today.This is a vary big problem today, The EPA and the SAE have just passed new rules and laws about this problem. The only problem is that the shop owners do not want to spend $4000 to $6000 ++ for a new recycle & recharge machine.
  15. alekska
    435
    138
    Atl
    Thanks Lech, lots of new interesting info on Prius AC in your posts. I looked at your photo gallery, too.
    Dare to write a sticky for users on how to prolong the life of Prius AC and how to screen AC repairman before letting them to work on your car ? :)
    Thanks,
    - Alex
    markabele likes this.
