Prius Aero Package
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Hybrid Effects, Jul 6, 2008.
  1. Hybrid Effects
    Hybrid Effects Junior Member
    97
    Orlando, Fl.
    With the blessings of Prius Chat Hybrid Effects would like to offer a introductory offer of the Prius Aero Kit at $500.00 Shipped to your door.:cell:
    Kit includes Wheel Skirts, Grille block with plugs and Aero Hub Caps.(Unpainted)
    Here is the best part, for $125.00 more you can have the Prius Aero kit professionally painted to the color of your car.
    That's just $625.00 for a new Hybrid car.
    Professional installation suggested.
    Call 1 800 515 9840 to order.
    Thanks Franklin
    Data Daedalus and Shelby profita like this.
  2. Flying White Dutchman
    4,374
    313
    including shipping wordwide?:D
  3. Hybrid Effects
    97
    Orlando, Fl.
    :rolleyes:Only on 50 Kits or more.
    Send email with address and port of entry if needed, and we will calculate shipping.
    By the way have you ever seen the flying Nun?
    Thanks Franklin
  4. Flying White Dutchman
    4,374
    313
    yes thats in france:D
  5. Hybrid Effects
    97
    Orlando, Fl.
    Good Grief were are the normal people.
    That is Sally Feilds with a Cam back on her head.
  6. Flying White Dutchman
    4,374
    313
  7. Genoz World
    Genoz World ZEN-style living
    797
    La Canada
    TO ALL - if you are gonna run the wheel covers all the time, you have to be careful about the cooling system of the brakes. these covers, (any covers that completely cover the rims) will cause a considerable reduction in air flow to cool the calipers/rotors and may/will cause brake fade, especially in severe downhill or longer braking periods. try to redirect air ducts so that air flow will be achieved from the inside of the rims.
    just my 2 cents for your safety.
    cheers
  8. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    In a normal car this is true. In the Prius in normal driving the brakes are not used much. We verified the lack of wheel brake use of this weekend, One of the attendees at the Cincinnati/Northern Kentucky Hybrid Group meetup had in infared video camera. He brought it because he wanted to see what the battery was putting out in the way of heat. He also took pics of the front wheels after a Prius pulled in after a 30 minute trip. The front wheels and brake disks had no heat registereing off of them. The front disk and wheel and the same temperature as the rest of the car. The Prius had just spent 30 minutes of all city dirving with 25-35 MHP speeds and several stop signs and lights. He has the pics. He said he would e-mail me a copy and if he does I will post them here.
  9. krousdb
    krousdb NX-74205
    580
    498
    47
    Raleigh, NC
    To reinforce what bestmapman said, I have 135k miles on the original brakes. The pads and shoes have plenty of material left. I estimate 400k before I will need my first set of new pads / shoes.
  10. chrisspaulding
    chrisspaulding sexy, high tech, fun
    556
    24
    Kentucky
    To your door?
    New Hybrid car?
    Both not a true statement. Someone may be able to hold you to that "to your door" line, even if they are out of the country :)
    Any data on MPG improvement with the full kit?
  11. Flying White Dutchman
    4,374
    313
    maybe do a test with long downhill driving? just for the facts!
  12. darelldd
    6,057
    389
    Northern CA
    Any hints on what is required for installation?
  13. Genoz World
    797
    La Canada
    OK, i'm NOT here to debate things about brakes, etc, whatever. i'm just pointing out safety facts. I realize that our PRIUS' does regenerate the battery when you completely lift OFF the throttle, but here's the bottom line.............................
    TOYOTA engineered the prius based on aerodynamics and fuel efficiency. IF it is more aerodymanic to completely cover the rims, I DO believe that TOYOTA would have done that.
    with this modification, what i'm saying is that IT MAY cause the brakes to work harder under more heat. to those that posted many miles with the stock brakes, THUMBS UP. my question is........................DID YOU COVER UP THE WHEELS to get such a long lasting wear? if not, then it's something to consider.
    that's all i'm posting. you dont get something for nothing, i'm SURE toyota considered that aerodynamic fact.
    i'm NOT insulting or saying the body kit wont work, it might, but then it MIGHT cause the brakes to heat up more. in so-cal, it's sometimes in the triple digit mark in temperatures, going downhill on highway speeds of 60+ and having to use the brakes will make me just a tad nervous with these covered rims, but we all have a choice.......................
    it's just food for thought.
    cheers, have a safe 4th of july weekend.
    Data Daedalus likes this.
  14. Stefx
    Stefx Member
    336
    FYI I emailed Franklin, the wheel caps are 15" only, no 16" available yet.
    Also, the wheel caps are installed to the wheels using double-sided tape.
  15. darelldd
    6,057
    389
    Northern CA
    Please say this isn't true. Just for the prototypes, right? These have to be removeable/replaceable for cleaning and inspection. Double-stick tape is not a real solution for something that is removed regularly. OR... are they stuck to the plastic wheel trim rings. That might make some sense as you can then just yank the whole assembly off.
  16. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Darell,
    Yes, they are stuck to the trim rings. Check out Franklin's website.
  17. Hybrid Effects
    97
    Orlando, Fl.
    The aero hub caps do actually have some ventilation. They are attached to your original trim rings with double sided stick tape and the tape actually spaces the aero hub cap away from the tire. It is not a lot of venting but it is more than the stainless moon type caps.
    Franklin
  18. Flying White Dutchman
    4,374
    313
    IMO toyota did not go the full wheel close and no wheels skirts like the insight because then the car will look ugly for a lot of people and it wil not sell good.
    thats what i think!
  19. Tchou
    Tchou Member
    161
    Yes I Agree this kit makes it ugly.
    Also for the safety warning, everyone answer was that the Prius doesn't use the discs a lot, just think about in what situations the discs are used then...
    If I was in those situations, i'd just hope that the brakes will work at 110% and not 80% due to bad cooling.
    and no I don't drive a BMW... (but BMW knows for a long date that brake cooling is important... )
  20. Flying White Dutchman
    4,374
    313
    because bmw is a performers car
    for speeding and fast breaking.
    and this is from the M5 thats the BIG fast sports car type off all bmw's
