Prius Aftermarket Wheels
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Steamboatsig, Feb 28, 2008.
  1. Steamboatsig
    Steamboatsig Member
    337
    Los Angeles
    2013 Prius Plug-in
    If you are curious what your Prius would look like with aftermarket wheels, Discount Tire, Custom Wheels, Truck & Car Rims | Discount Tire Co. has an interactive wheels system. The system allows you to choose your Prius's color and sizes up to 18". It is pretty cool, check it out.
    Btw, I have no affiliation with Discount Tire.
  2. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    Awesome find! Too bad they don't have Tideland Pearl for the paint colors :).
  3. Jimbo69ny
    Jimbo69ny Active Member
    712
    107
    Ithaca, NY
    I know this is an old thread but I was hoping someone could give me some advice on picking out a new set of wheels for an 08 Prius.
    I assume that it could potentially reduce the fuel economy slightly. Is that true? Would it be noticable?
    Thanks for your help.
  4. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Yes, the mpg loss will be very noticeable if you go with a 17" or larger wheel.
    Handling and looks are greatly improve if you choose the right wheel.
    To minimize the mpg as much as possible try to use the lightest wheel you can afford and a set of LRR tires which again are as light as possible.
    You could lose between 4-6mpg so go into this expecting that.
  5. sidecar
    sidecar Member
    342
    44
    Australia
    just as F8 says, fuel economy and acceleration/braking. Take a look at this post in a WRX forum. Only a 1" increase in wheel (not tyre) diameter, but a 47% increase in wheel weight.
    NASIOC - View Single Post - Wheel weight vs. acceleration test question
    what seems odd to me though, is that there is no evidence of this working the other way, that is to say performance gains from ultralight 15" wheels.
  6. drew935
    drew935 Member
    168
    22
    Nor Cal
    While this is true, it is not always the case.
    My 17" BBS STI forged wheels are lighter than the stock 16" wheels that came with the car.
    With the prius, you have a limited number of wheels and tires to work with and stay within +/- 1lb of the stock wheel and tire setup ;)
    nasioc - another forum I visit once in awhile
  7. Jimbo69ny
    712
    107
    Ithaca, NY
    Is there a list somewhere of the lightest wheels available for the Prius? Id really like to upgrade the wheels but I want dont want to lose too much fuel economy. Oh and I also want world peace and a supermodel for a wife....
  8. sidecar
    sidecar Member
    342
    44
    Australia
  9. justana
    justana Junior Member
    60
    I've lost 8 MPG after changed to 18x8...:(
  10. sidecar
    sidecar Member
    342
    44
    Australia
    wow thats a lot, what wheels and tyres do you run ?
    oh I see you just posted
    2012 BBS CH-R
    225/40/18 ZR Continental Extreme Contact
    B&G lowering kit
  11. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    :( I'm sorry to hear that. Sometimes the hit can be quite large depending on the combo.
  12. Jimbo69ny
    712
    107
    Ithaca, NY
    Yeah that sucks. To me, new wheels wouldnt be worth 8mpg. 2-4 maybe but 8 sucks. :/
  13. justana
    60
    Yeah, i was gonna put OZ with only 16.5 lbs, but I like BBS better even weight 20 lbs. But its still way better compare my previous car that take only 16MPG...:(
