Prius Airbag system
Discussion in 'Gen 2 Prius Main Forum' started by mr5150, May 7, 2005.
  1. mr5150
    mr5150 New Member
    Does anyone know if '05 Prius has the ability to detect front passenger weight and or seat position relative to the airbag to determine whether or not to deploy, or at what rate to deploy? I know it's dual stage, but I wasn't sure if that's just used for type of impact.
    Thanks, Larry
  2. bobc
    bobc New Member
    361
    Durham, NH
    I thought that the definition of a dual stage airbag is to know the location of the passenger, but maybe I have this wrong...
    I'm unsure if it senses the position of the seat. I should've looked when I had my passenger seat out....
    As for the weight thing, it doesn't sense the amount of weight. Only that a certain amount of weight is required to let the system know that there is a passenger. A contact is made when the passenger sits down.
    This is what the sensor looks like. This is looking at the seat bottom, just under the upholstery and from the rear of the seat looking forward...
    Cheers,
  3. robinsod
    robinsod New Member
    37
    Kerrville, TX
    The Prius detects the presence of a passenger AND the position of the seat. Thus, it will adjust the airbag parameters depending on the seat position.
    Cheers
    don r
  4. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    It also detects the position of the driver seat to adjust airbag deployment intensity.
  5. bslande
    bslande New Member
    So, my salesperson told me that the passenger airbag would deactivate with a child in the front seat. I have heard of this in other vehicles, but in those there is usually and on/off indicator somewhere. She directed me to a page in the owners manual, but the only thing I see in the owners manual is "Toyota strongly recommends that all infants and children be placed in the rear seat of the vehicle"
    She said that most Toyota's have this feature and was telling me a page to reference in the owners manual. Is this one of the options that I don't have? Just curious, obviously I am not putting my kids in the front seat, just would be good to know if it was at all safe to do so in a pinch.
  6. MarinJohn
    MarinJohn Senior Member
    3,945
    304
    RE: Children in the front seat...this is an important question. Naturally, they go, and belong in the back. However, all that begging to sit in the front on short trips sometimes wins me over. DanMan, do you know if the passenger bag deactivates if a child is in the front seat?
  7. Tideland Prius
    16,125
    Also, does anyone know if it has a position sensor. Not for the seat, but for the occupant so as to know whether to deploy the airbag or not depending whether the passenger is in the perfect position to be hauled into the airbag :p
  8. DanMan32
    3,799
    26
    Tampa Bay, FL
    There is a sensor to detect if there is weight on the passenger seat, as Bob's post shows. It doesn't directly go to the SRS ECU at all.
    The seat position sensor was for the driver side airbag.
    The system does detect if the buckles are being used, but I don't find any information on how that information is used.
    Only the driver side buckle and seat position sensors go directly to the SRS ECU. I would imagine the passenger seat information comes from SIL through the body ECU, if it gets to SRS at all.
    So, at best passenger airbag is disabled if no weight is in the seat, otherwise it is on. I am suspecting however that the airbag deploys whether seat occupancy is detected or not. The occupancy detector may simply be for the passenger buckle warning lamp.
  9. Leo
    Leo Leo
    81
    Ottawa, Canada
    This thread is an important issue for me. I pick up my Prius next Wednesda y (August 3). My wife is a slight woman, around 100lbs. She is worried that she would be killed by the bag if her air bag deployed. She's read about children in the front seat being killed (neck broken) and she doesn't want that to happen to her. She says she's about the same weight as some children around 12 years old, and she's read about 12-year-olds being badly injured by the air bag.
    I don't suppose there is a disabling switch for the front passenger seat, is there?
  10. Jared
    Jared Member
    209
    Long Island
    Leo,
    I would not worry about it. The main thing is for her to wear her seat belt and position the seat well back. I think the people injured or killed by air bags were not wearing seat belts. Also, air bags are much better now than the earlier generations. 80% of the safety factor comes from wearing the seat belt.
  11. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    Heres what the NHTSA says about children and air bags:
    "Air bags pose special hazards for any children who ride unrestrained or incorrectly restrained in the front seat. Like all occupants, children should always be properly restrained in safety seats or safety belts. Unfortunately, surveys indicate that as many as 35 percent of young children ride unrestrained. Pre-crash braking may throw an unrestrained child against the dashboard at or near the passenger air bag location. When this happens, the inflating air bag and its plastic cover can violently impact the out-of-place child with such force that it can injure or even kill the child. The safest place for all children is correctly restrained in the back seat of the vehicle."
    So, it sounds like the issue is whether or not the passenger is properly restrained, not the weight of the passenger.
  12. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    Here's a web page that talks about air bags and also references "short statured adults" is several places.
    http://www.ou.edu/oupd/kidseat.htm
    (search for the word "short" on the page)
  13. Leo
    Leo Leo
    81
    Ottawa, Canada
  14. Tideland Prius
    16,125
    Always use your seatbelt and sit as far back as possible. This may be a generalisation but why do most women drive with the wheel right up to their chest? I hope they have the airbag disabled.
  15. tleonhar
    tleonhar Senior Member
    1,541
    34
    Belle Plaine, MN
    I'm not sure where I read this, if it was in the manual, sales lit. or on a website. But if I recall the Prius has a weight sensor in the seat. If you are under a certain weight, the deployment force of the airbag is reduced.
    Terry
  16. tleonhar
    1,541
    34
    Belle Plaine, MN
    Good article, thanks!
