Prius alpha 7 seater JDM overhaul
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by ahmad ashfaq, Mar 19, 2019.
  1. ahmad ashfaq
    ahmad ashfaq Junior Member
    57
    islamabad islamabad
    2011 Prius Alpha
    Dear Folks , this is a big one for me ,
    I bought this prius in 2014 for $19,400, it was 31000 KM driven , now its 185000 KM .
    the rings on the engine are weak , consumes oil , I have the option of importing used engine , HV battery , ABS , Exhaust and other parts from a salvaged Prius alpha in Japan , expected cost of imported parts is around $3000 to $4000 ,
    i can sell this prius for $15000 and then i have the option of buying the used prius 2014 , 2015 for $22000
    I am wondering if i swap the engine , HV battery and keep it for 4 more years , or sell it and buy the newer model ?( which are driven 30000KM in Japan ) ,
    I like my prius and provided the options we have for my budget , i couldn't have any better car like Rav 4 etc , we have limited options of vehicles available in Pakistan ,
    #1 ahmad ashfaq, Mar 19, 2019
  2. mikefocke
    4,040
    1,839
    Sanford, NC
    What confidence do you have that the parts from the salvage car will be good? Who will do the engine swap? Everyone has a different tolerance for risk. And different financial resources. And your country to country parts makes things even more risky.
    ahmad ashfaq likes this.
  3. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    HV battery on those are Li-ion. Are you confident it is no longer good? Li-ion batteries are stronger than the NiMH batteries that we get here in the USA....
  4. ahmad ashfaq
    57
    islamabad islamabad
    2011 Prius Alpha
    well the Japanese Vendors can be trusted , but as you put it , these apprehensions are the reason i posted it here to get may be some one who already did a job like this , lets see if some one from New Zealand or Australia has imported parts like used engine or HV battery from Japan and are happy .
  5. ahmad ashfaq
    57
    islamabad islamabad
    2011 Prius Alpha
    Yes you are right , the HV battery is good , but since there will be a shipment , and used HV are for 700 to 1100 US$ , its better to have one in store for that moment , when you need it and its not available , shipment takes about 60 days to arrive to where i live , infact the ABS is also working , but again you never know , the Prius alpha is not manufactured here in Pakistan , hence no parts avilable
  6. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    So you can have a newer Prius v for $22k - $15k = $7000. Your other option is buying used replacement parts for $3k to $4k. Does that include installation fees? I wasn’t clear on that I’m afraid. If not how much for installation? Other parts will eventually wear down so this is a complex decision....
  7. ahmad ashfaq
    57
    islamabad islamabad
    2011 Prius Alpha
    installation is $300 for all , indeed its a complex one , i couldn't decide myself , car still drives better then local available cars, thats why i decided to keep it for family .
  8. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    $300 for installation is REALLY CHEAP! As long as good workmanship that’s the way I’d go. Here it is cheaper to keep an older car than to buy a newer car, plus labor rate is much higher than there from your estimate....
  9. ahmad ashfaq
    57
    islamabad islamabad
    2011 Prius Alpha
    yes , i have seen friends buying used car for a very good price Dallas Fort Worth area , we on the other hand are paying too much for even a used one e.g a used prius 2017 with 50 to 70 thousand on odometer is available for $27000 here , which is too much for an old car so mostly consumers would stick to older vehicles .
