Prius alpha odo not counting
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by faizaldal6, Aug 3, 2020.
  1. faizaldal6
    faizaldal6 Junior Member
    England
    2012 Prius Alpha
    ----UK----
    I have just purchased an import Prius alpha everything on the dash display works as it's supposed to trip A B etc how I've noticed the ODO display is not not counting how much milage it's done checked it on diagnostis on the and on the display function it's not showing the milage only a @ sign what can be the problem ? Any help appreciated thank you
    52,391
    someone possibly manipulated it to show lower mileage than actual?
  3. PriusCamper
    PriusCamper Senior Member
    13,063
    5,305
    Pacific Northwest, USA
    Have you tried disconnecting the 12v battery for a few minutes to reset the system?
  4. faizaldal6
    England
    2012 Prius Alpha
    ----UK----
    Not yet will that work ? Does I've put on a snap on scanner on the the vehicle information on ODO reading it's showing @ ?
  5. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    Have verified your odo reading on online?
  6. faizaldal6
    England
    2012 Prius Alpha
    ----UK----
    How can I do that ? Any suggestions
  7. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    If your car is JDM, you can varified genuine odo and auction grade at jpcenter.ru with your chassis numbe.
