Prius and Prius C Battery Modules
Discussion in 'Prius c Technical Discussion' started by ZackG, May 26, 2021.
  1. ZackG
    ZackG New Member
    Hi all, my prius c got error code P0A80 Replace Hybrid Battery Pack. I'm looking into repairing the battery and need to ask, can I use normal prius modules or do they have to be prius c?
  2. Leadfoot J. McCoalroller
    7,173
    6,718
    Pennsylvania
    2018 Prius c
    You can use "normal" ones, there just aren't as many in the c.
    ZackG likes this.
  3. Zhi
    Zhi New Member
    2015 Prius Plug-in
    The modules I got off eBay indicated they were also used in certain years of the Camry, Avalon, and various other Toyota/Lexus vehicles, so you are not limited to a sourcing from a Prius C.
    #3 Zhi, May 27, 2021
    ZackG likes this.
  4. ZackG
    ZackG New Member
    Ok, thanks! Do you know if a 2015 hybrid battery and a 2012 are interchangeable?
  5. Leadfoot J. McCoalroller
    7,173
    6,718
    Pennsylvania
    2018 Prius c
    I don't know. Obviously the modules are and the container is, but the big question is the integrated battery ECU & its wiring harness. If there's anything you'd have to swap, it would be that.
  6. Danny13pruisc3
    173
    27
    maryland
    what dd you end up doing?
