Prius as a backup generator help
Discussion in 'Gen 3 Prius Main Forum' started by johnnychimpo, Oct 5, 2021.
  1. johnnychimpo
    johnnychimpo Active Member
    514
    112
    Monterey
    I have seen so many threads and either there is no good explenation as to a turn key how to
    or they just add a battery and use a standard inverter.
    I would like to use a data center ups 240v and connect it to the traction battery. has anyone done this successfully? if so can someone point me in the right direction.
    THanks.
    privilege likes this.
  2. ChapmanF
    18,546
    There's this whole meta-thread, filled with links out to other threads for about every different generation of Prius where anybody's done it. Maybe you've already looked at those? I'm not sure where you're likely to find more than that.
    fotomoto likes this.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Not much of a mainline market for a 200 volt dc in to 120 volt ac out inverter much less 220 volt ac out. Lots of chatter about it in the last 14 years on this site some have come along but......
    Seen many old scientific ones on ebay but very old. I would not use my hybrid battery as a test bed.
  4. hill
    8,921
    Not only is a very small aftermarket demand, but there are a couple of new cars coming out that can backfeed power - weather for a work-related use or emergency power. That will certainly take away from the already small niche folks making aftermarket kits.
  5. AzusaPrius
    AzusaPrius Senior Member
    2,232
    930
    @hill
    So you think people will spend more buying a new car just to get emergency power versus buying a plugout kit from plugoutpower.com and using their hybrid they already have?
  6. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    No, I think the market is so small that there will be one or two people wanting to use their hybrid car as an emergency power source. The rest will just buy a small portable generator.
  7. AzusaPrius
    2,232
    930
    @Maarten28
    The established hybrid market is so small?
    Only one or two people would use their hybrid?
    I think you have it the other way around, one or two people will buy into this new hybrid market with power generators.
  8. ChapmanF
    18,546
    I suspect Maarten meant the market for plug-out style add-ons to hybrids that don't come with them.
    I have nothing against Randy's products, I'm glad they're out there, and I'm sure he is pricing them however he has to so the numbers work out; they just come out high enough to make the decision not super easy. I mean, yes, they're less money than a newer car. But if a newer car is anything you might be thinking about ... or if a standalone generator is anything you might be thinking about, then I'm guessing a lot of people who might snap up the plug-out if it were priced, say, in the hundreds, would look at the price in the low thousands and think "but there could be other advantages to having the newer car ... or other advantages to the standalone generator that can still power my house when I'm using the car." The price is enough to sort of dampen the impulsive-purchase effect and kind of make you think through all the angles.
  9. AzusaPrius
    2,232
    930
    There are a lot of reasons to use your hybrid versus buying even a stand alone generator, for one we know the prius engine is built to save fuel, second it will not be as loud and constantly running because of the hybrid system design.
    Third, the gas tank in a hybrid is bigger than a generators so you have more time between refills.
    I hear you have to maintain common genrators even when you do not use them otherwise they will not work.
    That wont happen since your already using your prius.
    The hybrid will always be ready, just put her in ready.
    Last but not least, you wont have to buy another car and sell the hybrid you are ditching.
    Then apply for a loan and start making payments again.
    Not to mention higher insurance rates on that new car.
    Yea, I guess I will be one of the two smart ones that buys a plugout kit from plugoutpower.com and then save even more money by using a promo code 7373
  10. Maarten28
    415
    224
    Netherlands
    I said "one or two people wanting to use their hybrid car as an emergency power source". No idea why you think I am saying the hybrid market is small or only one or two people would use their hybrid.
    And my comment was against your assertion that people would buy a new car just to to get emergency power. I think most people will just buy a generator.
