Prius as a power source?
Discussion in 'Gen 2 Prius Technical Discussion' started by MrK, Jul 25, 2006.
  1. MrK
    MrK New Member
    30
    I've been reading it for several months, and let me say that I'm extremely impressed with the quality of information available here. This is my first post to Priuschat.
    Due to recent storms, much of the St. Louis area was without power for several days. Lowes and Home Depot sold every generator they could get.
    I've got a 1500/3000 (surge) watt inverter, and I was wondering if I could hook it up to the 12 volt system of my 2006 Prius. I figure that the high voltage battery would keep the 12 volt system charged and, as the HV battery ran down, the ICE would start and charge it back up. This arrangement seems much more efficient than using a generator, as the generator's engine is always running, regardless of demand. The Pruis would run only to recharge the battery as needed.
    Can this be done, or is my understanding of the HV/12 volt system flawed?
  2. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    See http://priuschat.com/I-need-power-outside-...ter-t22351.html for a little more reference
    Note that the power outlets are fused (combined) at 15A, Which probably doesn't lend itself to a 3000W inverter too well.
    It is definately possible to use the prius to power smaller electronics, like a laptop or a fish tank, but i don't think i would want to try to use it to power standard household appliances.
    One possible solution would be to add your own fuse connected to the battery to allow higher current draws, but you'd want to check first on the current draw thats allowed between the hybrid battery and the 12V system. unfortunately, i don't have that info here anywhere
  3. chogan
    chogan New Member
    590
    Vienna, VA
    <div class='quotetop'>QUOTE(MrK @ Jul 25 2006, 02:17 PM) [snapback]292076[/snapback]</div>
    MrK,
    Try this URL to see a broad-brush description of how somebody else set this up.
    http://store.yahoo.com/yhst-6122897076971/priusinverter.html
    If you want to pull up to 1500 watts, connect the inverter directly to the 12 volt battery. You sound like you understand that level of current would fry the cigarette lighter socket.
    Another site I saw (but can't remember the reference to) suggested that, due to the small size of the Prius 12 volt battery, get another regular-sized car battery connect that in parallel with the existing Prius battery (jumper cables), and run the inverter from that. That's to give you a little more surge capacity, as the Prius 12 v battey is tiny.
    I'm not sure I'd pull 1500 W even then. I'm sure I'd never go over that, because of the following.
    I'm not a technical guru, but my understanding is that the link between the traction (big) battery and the 12 volt battery has a limit of about 1500 watts. So that limits the rate at which you can steadily pull current out of the 12 volt battery. I'm not sure whether you'd damage anything if you tried to pull more. But yes, as I understand it (read the invertersrus story), you have the story right. Turn the car on, pull power out of the 12 volt, the traction battery will keep the 12 v up, then the engine will automatically cycle to keep the traction battery voltage up. And you have the quietest generator on the block.
    If you follow the priuschat thread recommened in another post, be sure to go to the priups site. It's a hoot. And it has a lot of good technical detail. I think that's the guy who explains the 1500 watt limit in steady current draw from the 12v battery. If you want to pull more than 1500 watts, you need to connect to the traction battery directly. DO NOT DO THIS, but the site's hilarous. The guy ended up wih a system that could power his house (like 18kw or so) by connecting the traction battery to a commercial UPS whose lead-acid batteries were shot.
    I bought a 1500 watt inverter for my business, and a full size car battery, with exactly this scenario in mind, but haven't ever had to hook it up to the Prius 12 V battery (which, by the way, is in the trunk, right hand side, under a removable plastic panel, and is about the size of a motorcycle battery.) So I can't say firsthand, but the article on invertersrus looked right to me.
  4. chogan
    chogan New Member
    590
    Vienna, VA
    MrK,
    Better also read this:
    http://priuschat.com/lofiversion/index.php/t13502.html
    Particularly the part about, if you blow the 100-amp fuse on the 12-volt side, the car won't run. That guy seems to have done the correct and cautious thing, which is to put a 60 amp fuse in line with the inverter. If that fellow's correct, then trying to draw 1500 watts may be asking for trouble. I swear I've read people who've drawn more than that, but I believe I'd be cautious about the load.
  5. MrK
    MrK New Member
    30
    <div class='quotetop'>QUOTE(chogan @ Jul 25 2006, 01:13 PM) [snapback]292111[/snapback]</div>
  6. MrK
    MrK New Member
    30
    Thanks to all for the prompt response. I see that I'm not the first to think of this.
    Just to clarify, I wasn't thinking of using the cigarette/power sockets; I intended to hook up directly to the 12 volt battery with jumper cables. In fact, having read that the 12 volt battery is 'undersized', I was considering wiring around it to a deep cycle battery or a full-size car battery, just like chogan suggests.
    I wasn't aware of the 100 amp fuse that must be protected, and while I believe it's a very good idea to put a smaller fuse in-line, I question the need to do so. My rationale is that I'll be drawing down the battery, and the Prius will try to keep it charged. If I were to be using as much power as my inverter can put out, it seems to me that my battery will eventually run out of juice because the Prius may only charge to one-half or one-third the level of usage. It's not clear to me how pulling power directly from a battery would cause a fuse not in the circuit being used to blow, as the Pruis can only charge to a given level. Not that it can't, I simple don't understand why it would. But then, better to be safe than sorry. I'll put a smaller fuse between the Pruis battery cables and the inverter.
    Again, thanks for all the coaching. I really appreciate it. It's this kind of response that makes Priuschat such an asset.
  7. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    <div class='quotetop'>QUOTE(MrK @ Jul 25 2006, 04:58 PM) [snapback]292179[/snapback]</div>
    The 150 amp fuse (not 100, I believe) is in the charging line to the 12v battery (from the Prius HV inverter - actually a DC-DC converter). That's where your power to the external inverter comes from, not the toy 12v battery (which would be discharged and ruined quickly if asked to supply high current). The best reference on this is Bob Wilson's work on using the Prius (2001-2003) as a 1Kw UPS.
    http://hiwaay.net/~bzwilson/prius/priups.html
    If you want more power you need to connect directly to the traction battery as in:
    http://www.priups.com/
    by Richard Factor.
    Good luck and have spare fuses in your kit.
    JeffD
  8. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    <div class='quotetop'>QUOTE(jdenenberg @ Jul 26 2006, 06:36 AM) [snapback]292526[/snapback]</div>
    The fuse on my 2004 is 100A - just looked under the hood. Note the reference/layout on the fuse/relay cover - the 100A DC/DC is the fuse we're concerned about.
  9. tochatihu
    tochatihu Senior Member
    9,851
    3,813
    Kunming Yunnan China
    2001 Prius
    I have a 1000 watt modified sine wave inverter hard-wired into my 2001 Prius, and (am at least one) person who added a 60 amp fuse to sacrifice itself before the Prius' 100 amp one blows. You are absolutely dead in the water if Toyota's fuse opens. It is rather costly to replace and must be unbolted under one of the engine compartment fuse boxes. So this is an area to stay away from if at all possible.
    Fuses are apparently somewhat tricky because they vary in terms of how fast they open at different levels of overload. ANL fuses (such as I have added) are quite sluggish according to the specs I have seen; this is why I chose a 60 amp which at first appears to be small. This fuse has never blown for me, but I don't use quite as much power as Bob Wilson does for example.
    Presumably all inverters of the 1000 watt or so size class have internal fuses but I am somewhat conservative when it comes to the Prius electrical system. When you are pulling big amps from there, don't be also running the headlights, HVAC fan, or any other big 12 volt loads.
    If you decide to install a big inverter, make sure its power and ground leads are as short as possible and not smaller than 6 gauge wire. Better still 4 gauge.
  10. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    <div class='quotetop'>QUOTE(MrK @ Jul 25 2006, 03:58 PM) [snapback]292179[/snapback]</div>
    I'm not an expert, but the load (watts) depends on both volts and amps. The batteries are being charged to a particular voltage, like you say, but that doesn't control the amps that are being drawn from it, so you can definitely overload the battery draw if you don't limit that aspect with a fuse. This is particularly true for controlling surges, since most equipment needs a momentary blast of power to get started, then keeps running at a lower wattage. And it is in the circuit (from what I've just recently read but it makes sense), since the power comes from the gas, to the ICE to the main traction battery (at intervals) where it's stored. Then from the traction battery thru the DC->DC converter (and the internal 100 amp fuse) to drop it to 12V where it keeps the aux battery charged, which is where you likely have the inverter attached. From the aux battery it also has other paths, to the A/C, lights, stereo, a 15-amp fuse to the cigarette lighter, etc. Add them all up and you better use less than 100 amps, hence the safety measure of using a 60-amp fuse on the inverter. 60 amps * 12v = 720 watts peak. If you make sure you turn off all accessories beforehand, you could probably use a 75 amp fuse (do they sell that size? I haven't shopped for anything that big before) for 900 watts.
    Interesting thread.
  11. MrK
    MrK New Member
    30
    Based on all the fine information provided to me, it looks like these are my short-range and long-range plans. Note that I don't intend to drive around with all this connected; I'm simply implementing connections that will work for the next major power failure, which may be years away.
    In the short-term: I intend to wire around the prius mini-battery by disconnecting it, and in its stead, connecting to a standard or a deep cycle battery off of which I'll have my "too large" inverter connected. This battery will provide the surge capacity for startups, but I'll intend to keep the running capacity to 1,000 watts or less. And I'll put a fuse or circuit breaker in the charging line between prius and standard battery. Don't want to blow the 100 or 150 amp fuse, whichever it is. (I guess I should look it up.)
    Long range plan: I like Richard Factor's PriUPS project and research. I had never considered doing anything like that until I read his material. I've come across an APC 3000vA/2,250 watt UPS that was being scrapped (case damage, bad batteries, but still functional), so I've acquired the key piece of equipment to produce 2,250 watts. Surge capacity is supposed to be significant, too, but I haven't located any numbers. I'm trying to locate the balance of materials/equipment, with the ultimate goal of duplicating Mr. Factor's work, but I'm not in a rush to complete this. (Anybody know where I guy near St. Louis can find switching transformers to reduce 230 volt DC to 48 volt DC??)
    The main advantage to the PriUPS power production appears to be the doubling (or more) of usable wattage and the fact that the UPS-type inverter generates a cleaner (that is, purer) sine wave in comparison to the Vector inverter (modified sine wave). As I understand it, the pure sine wave is much easier on the refrigerator and deep freeze motors.
    How about this for a wild idea? During a power outage, I could use BOTH systems at the same time, so long as I keep the total draw of power below the regenerative threshold of the High Voltage battery. Again referring to Richard Factor's research, at a draw level of 4-5kW, the Prius engine would probably run full-time to keep the HV battery charged. But it's quiet, and the fuel consumption would likely be less than a free-standing generator of equal wattage. And power is only drawn from the system as needed, as opposed to a generator that runs whether the refrigerator is on or off. (I realize a generator doesn't run as hard during "off" cycles, but it's still running and consuming fuel.)
    Have I gone off the deep end?
  12. crichman
    crichman Junior Member
    36
    <div class='quotetop'>QUOTE(MrK @ Aug 3 2006, 10:29 AM) [snapback]296929[/snapback]</div>
    Maybe. Welcome to the pool.
    I've also used Richard's approach and I'm mid-way through the project. You may want to contact him directly for more information about the switching power supplies he used to convert Prius traction battery voltages to the 96 or so volts required by sine-wave UPS systems like the HP/Compaq R3000 XR.
    In my case I'm still expermenting with mods to make sure that enough juice is available to the UPS to meet the surge demand from my fridge compressor. More info when I'm happy with the solution, but for now I can verify that I do get sine-wave power from the UPS via the Prius -- well more than you can extract from the low-voltage circuit.
    Charlie
  13. crichman
    36
    Update: It works!
    I followed the approach suggested by Richard Factor. A version of his "portable Large System A" from www.priups.com is now installed in my basement and cabled to a Prius when needed. It runs my fridge and my furnace fan successfully using clean sine-wave power, so my goals have been met.
    My implementation differs from his slightly. Mine's in the house, not in the car. The socket in the Prius has a fuse (rated for DC and for the right voltage.) The modified switching supplies themselves have been wired to DC-rated fuses as well. I used a cheap mechanical transfer panel instead of relying on the UPS load-switching circuitry. And I found I needed to add a couple of big capacitors to buffer the switching supply outputs to meet peak demand when the fridge compressor kicks in.
    Hats off to Richard, who was extremely helpful.
    Charlie
  14. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Of course the more conversion steps you put inline, the less
    efficient the whole rig is. For possibly the ultimate in klunkiness,
    see http://techno-fandom.org/~hobbit/cars/tds-priups/
    The folks fortunate enough to have directly 200V-compatible systems
    are doing it the right way.
    _H*
  15. M. Oiseau
    M. Oiseau 6sigma this
    270
    Tulsa, OK
    Dr. Fusco and I were asking about inverter installations the other day and since then I've been nearly obsessed with the idea.
    I've read references to a 150A inline fuse for the 12V DC-DC line to the Prius 12V battery. This 150A reference was then corrected to 100A with cautions not to risk blowing this "system" fuse due to difficulty and resulting high cost of replacement, recommending 60-80A positive terminal inline ANL type fuses.
    I was just poking around the 12V battery area and noticed a 120A fuse on the positive terminal for a line out that appears to be for all the car's 12V components. Is this consistent with the 100A system fuse because the little 12V battery provides current draw buffer over 100A?
    Does this mean a 100A fuse off the battery to an inverter, say 1250W or so, would be just as "safe" to the Prius system as the 60-80A fuses, especially if I drop a 300A peak draw or higher deep cycle battery in parallel between the Prius battery and inverter?
    Am I on the right track? I really don't want to zap my car.
  16. MegansPrius
    MegansPrius GoogleMeister, AKA bongokitty
    2,437
    27
    Chicago, IL
    <div class='quotetop'>QUOTE(M. Oiseau @ Apr 19 2007, 10:58 AM) [snapback]426034[/snapback]</div>
    I don't have any answers myself, but there's some good inverter discussion in this thread:
    My Prius is Powering my House
    http://priuschat.com/index.php?s=&show...st&p=363152
  17. MrK
    MrK New Member
    30
    [/quote]
    I believe some of the research that was conducted in the desert with a 1,000 watt inverter indicates that, as the total amperage draw approaches 70 amps (x 113.8 volts = 1,000 watts), the Prius will lower the voltage output so that 1,000 watts seems to be an internal limitation of the 12-volt system. While I haven't tested that theory, my own experience last winter seems to bare this out. I was running a 1,000 watt space heater, and I'd check the deep cycle's state of charge periodically. It was oftentimes in the 11.4 volt range. The next day I wired a gas furnace into the system (abandoning the space heater). I was able to run the furnace using less electricity, and this heated a whole level of my home, and the battery SOC improved.
    My own installation consists of a 1,500/3,000 watt surge inverter, a 12-volt deep cycle battery, and #4 wire cables. I installed the cables, one to the positive terminal of the battery, and the other to a ground, but not the same location as the batty's ground. (I used the bracket beside the Prius battery.) In the event of a power outage, I connect these cables to the deep cycle battery, and I wire the inverter to the second set of battery terminals on the deep cycle battery. I then run a heavy extension cord into the house. I trust that the deep cycle battery will provide surge capacity, but I haven't conducted any testing. I also need to fuse the circuit before the deep cycle, but haven't yet.
    I, too, am pursing the ability to use the HV battery. I've recently acquired a MGE UPS (8,000 watts), but I'm having trouble getting it to work at all. I think I need to know it's good before I connect it to the Prius, ala Richard Factor.
  18. M. Oiseau
    270
    Tulsa, OK
    MrK and Megan, thank you for the info. :)
  19. bwilson4web
    16,353
  20. Ethereal
    Ethereal New Member
    113
    Ocala, FL
