Prius at drive-thru and red lights.
Discussion in 'Gen 3 Prius Main Forum' started by PikRok, Mar 20, 2010.
  1. PikRok
    PikRok New Member
    25
    Pittsburgh
    Does the Prius use any gas when you are sitting at a drive-thru or at a stop light? I was told that the Prius does not use any gas when sitting still -- which is one of the reasons why I bought it -- but I want to hear the technical aspects from the experts.
    Thank you
  2. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    The technical aspect is relatively simple: the Internal Combustion Engine (ICE) stops running.
    There can be exceptions, like anything. But the majority of the time, the ICE will not be running when you are standing still. All of the Prius' functions will be handled by the hybrid battery (radio, movement, A/C, headlights, etc).
  3. PikRok
    PikRok New Member
    25
    Pittsburgh
    Thank God for a Prius and thank you for answering. :)
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Some additional thought:
    To meet emissions laws, the ICE runs long enough to warm up, so when first started, the Prius does idle on gas. Also if you are running the heater, most comes from running the gas engine.
    Even when warm, all power eventually come from the gas engine, so when you are running on battery, that will be recharge later by the ICE.
    But it does get GREAT gas mileage!
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    The prius is the best car to go through drive in's as its so easy to collapse the outside rear virew mirror. Drive ins...garage parking...toll booth. Anything that will catch that mirror. I do it automatically now.
    Open the window..pull the mirror in. Push it out as I roll away.
    Haven't nicked it yet. Great design.
  6. Tideland Prius
    16,146
    It'll also not use any gas while running in certain conditions, so it's not just when the car is stopped.
    2 people like this.
  7. Netmaster
    Netmaster New Member
    23
    In the same order of idea...
    Someone mentioned Drive in.. Let say i want to go to the drive in cinema (outside with a big screen and movie audio thru shortwave FM radio).
    If i put the parking brakes, does it cut all exterior lighting and will be able to watch the movie with AC or fan to keep me cool with the ICE off?
  8. mitch672
    mitch672 Technology Geek
    1,077
    197
    Randolph, MA
    If you put it in park, with the AC on, the AC runs off the HV battery, so the engine will be off, except when the HV battery State Of Charge dictates it needs charging, then the engine will start, to charge the battery. You must remember, ALL energy in the Prius is derrived from Gasoline.
  9. austingreen
    austingreen Senior Member
    13,574
    4,113
    Austin, TX, USA
    I'd say this is the biggest luxury feature of the prius. Engine off, unless you need to be on. Just the ac, no engine at stop lights. It's nice to slip into ev during traffic jams too. The engine fires up if you can go fast, or the battery starts running low.
  10. Bob64
    1,540
    92
    Virginia
    Keep in mind: the battery doesn't last forever.
    After 10 minutes or so, you'll notice the battery levels dropping.
  11. heidi
    heidi New Member
    Can the heating also run on battery with the engine off? I live in Canada so the heating is way more important to me than the AC, and it drives me nuts when I see people sitting there with the engine idling to keep the car warm.
  12. bisco
    49,441
    no, all heating comes from the engine. if/when you use heat in cool/cold weather you will notice a reduction in mpg.
  13. bisco
    49,441
    except energy stored in the battery from coasting and braking!
  14. richard schumacher
    7,663
    1,038
    United States
    To summarize, if you want cabin heat the car must be in "Ready". If you want A/C cooling the car can be in IG-ON but the engine will not start and the large traction battery will be quickly drained.
    The battery-safe way to use the A/C or any accessories for more than a couple of minutes is to leave the car ON ("Ready") and in "Park" (*not* Neutral). Then it will start the engine as needed to keep the batteries properly charged. You can do this until it runs out of gas.
  15. Sagitar
    Sagitar Junior Member
    59
    Ampthill
    In the long run, even they come from the ICE. Coasting or braking each use up kinetic and/or potential energy stored in the momentum and elevation of the vehicle and created by the ICE.
    This is true even when running downhill, since what goes down must, eventually, go up.
    The efficiency of the Prius doesn't come from getting something for nothing; it comes from wasting less of the energy that the ICE generates.
  16. going red baby!
    going red baby! still a n00b
    610
    96
    Los Angeles
    You know I read somewhere that my car has collapsible side mirrors but I couldn't do it. Then I forgot about it. Now I read your post, thought maybe I only tried the passenger door so went out and tried the driver door mirror and still nothing. :eek:
    Oh! Maybe the power needs to be on? I'll go try that. Nope. :(
    It's funny that my car has so many things I don't know it has... my last vehicle had NOTHING and I knew I wanted the Prius so it didn't matter to me what the amenities were, once I was ready to buy I went in and bought with a test drive that was a mere formality.
