Prius backup camera on sooner?
Discussion in 'Prius v Technical Discussion' started by bear15, May 23, 2015.
  1. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    Has anyone been able to figure out how to make the back-up camera come on sooner once you put the car in reverse? We find we have a little bit of delay. Any help appreciated-- thanks!
  2. fuzzy1
    10,170
    The primary delay I see is when the car and MFD are booting up, and there is little hope of improving this.
    When I shift later, the delay is far shorter. But when just trying to back the car out of the garage on EV without igniting the ICE, with intent of reparking, this boot-up delay does severely eat into the available EV time before the ICE automatically starts up.
  3. Mendel Leisk
    38,726
    Ours is in the rear view mirror: I've not noticed a lag. Maybe you've got the larger nav screen version, it takes longer to "boot"? To be fair I don't pay much attention to it, it's so wide angle I don't trust it.
    49,490
    i never noticed, but fuzzy must be right. typically, i only back up when starting.
  5. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    Yes, the problem is only with the initial reverse when I am backing out of the garage. The "Toyota" splash screen takes approx. 7 seconds or so. So we would need to find a way to not load the splash screen at the initial start-up.
  6. fuzzy1
    10,170
    I think there is more than simply the splash screen being loaded. If the radio was left on too loud after the last trip, I will discover it at powerup and want to shut if off immediately, but the audio controls are also nonfunctional for several seconds. That is why it seems like a bootup time issue, not just a splash logo display issue.
    #6 fuzzy1, May 24, 2015
  7. bisco
    49,490
    it's amazing that the car goes into reverse so quickly, but nothing else works.
    fuzzy1 likes this.
  8. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    Yes, but like with any device, if you eliminate the splash screen this typically reduces the boot-up time.
  9. Mendel Leisk
    38,726
    The backup camera on rear view mirror seems to come up fast. I'll try to remember to watch it closely, next start up. I can't recall any delay though, maybe because that's all it displays? It's handy location too.
  10. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Back into your garage/parking space. ;)
    Then no problem when you leave. :D
    valde3 likes this.
