Prius battery balance charging
Discussion in 'Gen 2 Prius Technical Discussion' started by DWJM2513, Jul 26, 2021.
  1. DWJM2513
    DWJM2513 Junior Member
    64
    24
    US
    I have a 2005 Prius I'm balance charging the cells in it and I cannot find any specs on them. Max charge, max mAh, charge/discharge rates, when to tell a cell is bad. I also need a bit of schooling on my SKYRC iMAX B6 Mini charger if anyone can help me set it up for these prius batteries. Thanks in advance! View attachment 213593 View attachment 213592 20210725_123320.jpg
  2. PriusCamper
    PriusCamper Senior Member
    13,055
    5,305
    Pacific Northwest, USA
    What part of the US are you in? Folks on here tend to be more interested in helping someone who lives nearby as there's so many people on here needing help you can't help everyone... Though if you do lots of googling with keyword ""priuschat" you'll likely find all the info you need.
  3. DWJM2513
    64
    24
    US
    I live in southeastern ohio. I have tried googling this topic and can't find any specifics on the batteries. I'll try it with priuschat in it next time
  4. DWJM2513
    64
    24
    US
    Heck, all I need is some kind of spec sheet or to talk with someone who's balance charged these cells before
  5. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    Have you looked at how these guys recommend first fully discharging all cells then charging? I know your charger is different but I think the key is to get all cells down to baseline low voltage then your smart charger may do the rest. Else maybe plan B and get a different charger?
    Battery Reconditioning Overview | Hybrid Automotive
  6. dolj
    dolj Senior Member
    8,558
    4,348
    Wellington, New Zealand
    I think you'll find they recommend fully charging first then a series of discharges going deeper in each successive cycle.
    At least, that's how I read it.
    SFO likes this.
  7. PriusCamper
    13,055
    5,305
    Here's a copy of a spreadsheet of some of my methods... Each module is 6800 milli-amp-hours... Max charge with SKYrc charger to me is 8.7v and I usually charge at 4-ish amps with those. Make sure you're using the NiMH option on the charger. Essential is a big fan for cooling... A thermal cam is helpful for finding cells that are running too hot.
    #7 PriusCamper, Jul 27, 2021
    SFO likes this.
  8. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
