prius battery cells
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by luka, Feb 19, 2019.
  1. luka
    luka New Member
    georgia, batumi
    I have question about prius battery cells, can i buy new battery cells for my prius?
    #1 luka, Feb 19, 2019
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Yes but it will cost $2500
    51,140
  4. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
  5. ericbecky
    ericbecky Hybrid Battery Hero
    4,381
    3,242
    Madison, Wisconsin
    Hi Luka,
    Not sure if you meant replacing all the cells (modules actually) or just a few.
    As answered above, replacing them all will cost you around $2500. You can have an independent shop do this for you. Benefit is that you'll also get a new case, new buss bars, new voltage sensing wires, new positive and negative leads and all new nuts and bolts.
    Of you just want to buy 1 or to NEW modules, that is also possible. Like to use as an electric bike battery or something. But there are better options.
    You cannot mixed old and NEW modules together in a Prius pack though. There will be too much difference between them and the car will not accept it.
    If you are looking to replace a few failed modules in your failing Prius pack, you'll want to buy USED modules. I sell to customers all the time.
    Clarify your question a bit and hopefully we can provide a better answer.
    RMB, Robert Holt and Raytheeagle like this.
