prius battery failed prematurely
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by GarytheGeek, May 8, 2021.
  1. GarytheGeek
    GarytheGeek New Member
    san jose
    i bought my 2008 prius from someone who claims to flip prius as a side gig. he told me that he replaced the HV battery in the prius recently with a Dorman battery and is selling it. he had a receipt to prove it. i bought the car 1.5 years ago and it ran great (until the cat got stolen, but that is another story) Then half a year ago i noticed that the battery was draining faster than normal. and 2 days ago the red triangle turned on. now the red triangle turned off but the battery stays at 2 bars. the OBDII has codes p3000, p2799, and p0A80. The battery can't be older than 2 years. what could cause the battery to fail that quickly. is Dorman that bad of a product? or is something else causing it to fail early.
    as for getting a new battery, i was thinking of getting it from electronhybridsolution because a toyota mechanic i am friends with recommended them to me. are they good?
  2. JC91006
    16,482
    8,397
    Dorman refurbished batteries are really that bad....actually most commercially refurbished batteries aren't very good. Their business model is profit over quality.
    If your Toyota mechanic "friend" recommended another refurbished battery, you need better friends
  3. GarytheGeek
    san jose
    then what should i buy instead that doesnt break the bank?
  4. rjparker
    rjparker Tu Humilde Sirviente
    7,965
    4,709
    Texas Hill Country
    Dorman and almost all battery suppliers are selling used batteries that are inspected for weak cells. The weakest are replaced with other used cells that are better. Some charge and discharge individual used cells many times in an attempt to break the laws of physics.
    To be honest, "refurbished", "rejuvenated" or "rebuilt" batteries are doing good to last 1.5 years. Things have changed in the last few years. New Toyota batteries are sometimes less than $2k and at least one supplier provides diy new cell replacements. The new batteries will easily last 175k-200k miles or eight to 15 years.
    Prius Battery Replacement Kit (GenII/GenIII) with NEW custom cells | PriusChat
    #4 rjparker, May 9, 2021
    jerrymildred likes this.
  5. GarytheGeek
    san jose
    ok, i will look into that.
  6. bisco
    49,447
    you just need a module replacement
  7. rjparker
    7,965
    4,709
    Texas Hill Country
    Dorman usually offers a 24 month warranty. Might check with the flipper.
  8. royrose
    royrose Senior Member
    1,389
    949
    Foot of Pikes Peak
    The founder of that newpriusbatteries is active on this forum: @2k1Toaster
    If you are not comfortable installing it yourself, maybe your mechanic friend will do it for you for a reasonable price.
    #8 royrose, May 9, 2021
