Prius battery in summer heat
Discussion in 'Gen 2 Prius Main Forum' started by Berch1943, Jul 25, 2018.
  1. Berch1943
    Berch1943 Member
    146
    Arizona
    With summer heats here going as high as 115 - 120 F , I am concerned how this would affect the lifespan of the hybrid. As soon as I get in the car , it's burning like an oven , I can't even touch the steering wheel. And using the turn signal sounds like it's low pitched, does anyone else get the same problem? So how well does the battery do, temperature wise?
    51,148
    poorly. run your a/c all the time, try to park in the shade, drive gently, get your windows tinted, clean the cooling fan, etc.
    Starship16 likes this.
  3. Berch1943
    Berch1943 Member
    146
    Arizona
    Some people mentioned using the recirculation on the ac is a good idea. And what if there are no shades where i park?
    51,148
    get interior sun screens, try to park with the front toward the sun, the battery is in back. leave the windows cracked if possible.
  5. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    The silver on the outside suckers that go on the inside of the windshield and good window tinting on the sides and rear, and full steam ahead with the air conditioner, check the air flow to and from the traction for clogs.
    It’s an 07’ get a new traction battery
  6. PriusCamper
    PriusCamper Senior Member
    12,062
    4,894
    Pacific Northwest, USA
    Heat is the greatest weakness of these incredibly reliable cars. If I lived in an area as hot as yours. I'd rent a space in a parking garage... It'd probably be way cheaper than the repair bill. Also it has alot to do with the color of your vehicle in terms of heat damage to hybrid battery. I read on here long ago that if you're buying used and live in a hot climate a white Prius battery pack is going to be way longer lasting then a pack in a car that's a darker color.
  7. golfmk681
    golfmk681 Active Member
    262
    105
    los angeles, ca
    I’m I’m gonna park next to a tree that cast a full shadow when I leave for work
  8. JC91006
    16,673
    8,518
    You won't have to worry with a new battery
  9. golfmk681
    262
    105
    los angeles, ca
    Really. When does heat play into it? Like after 150k Miles?
  10. JC91006
    16,673
    8,518
    That battery should outlast your car, don't need to worry about it in heat or no heat. Just go back to enjoying the drive.
    It'll take a good 8 years to ruin a battery, even in Arizona heat, and you live in California
