Prius Battery Information
Discussion in 'The File Library' started by efusco, Sep 1, 2004.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    This is an interesting press information article about the Prius' hybrid battery. How and why it was chosen, a little techy stuff, and some info about Li+ ion and supercaps.
    I found the last paragraph about how capacitors are currently used in the emergency braking system in the Prius particularly interesting.
  2. eak354
    eak354 Member
    447
    HI
    good reading! thanks!
  3. Frank Hudon
    Frank Hudon Senior Member
    4,147
    Evan the capacitor unit was one of the things damaged on the wife's 2k4 in the accident and at the time it was $1700USD. If you want to see it just take out the black lower storage box in the lower hatch and have a look at the black box just to the left of the aux. battery. There are 27 capacitors in there that provide the brake pump with power in the case of the 12Volt battery going open circuit and not being able to power the pump which charges the accumulator with pressure to provide the friction brake to stop the car.
  4. Ray Moore
    Ray Moore Active Member
    857
    52
    Texas Hill Country
    This car just keeps on surprising me. I continue to find myself humbled as an American looking at Japanese mainstream technology that our American auto makers can't even approach. Thanks Evan.
  5. efusco
    19,891
    1,192
    Nixa, MO
    There are people out there that take offense when I refer to this car as the most technologically advanced on the road. I think those people don't understand the complexity and refinements at so many levels in the Prius. Glad folks finally found this article of interest as I thought it was good reading.
    Silver_782 likes this.
  6. Elad Nava
    Elad Nava New Member
    Thank you very much! :)
  7. Ernest Erickson
    Ernest Erickson New Member
    16
    Arizona
    Technology
    Nothing to read!
    The highlighted link runs to ebay....(?)
  8. Tideland Prius
    16,127
    There was an attachment that was lost many years ago during one of the forum’s major upgrade.
    Icyair likes this.
  9. chronon
    chronon Active Member
    601
    105
    here and there aint be in frozen wasteland no mo..
    have you seen the replacement bats from china ? - instead of 28 packs, you have only 14, they take nimh D cells? to make a block of 12 of them to give the same voltage and amps of the parametric grid oem's -- so instead of 28 slises u have 14 to simplify things and much better looking connectors -
