Prius blown engine- what to do?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dave Brewster, Jun 24, 2019.
  1. Dave Brewster
    Dave Brewster New Member
    Littleton, CO
    I recently bought a 2007 Prius with about 107k on craigslist. I had a pre-purchase inspection done and everything looked good. Last week it was time for an oil change so I took it into the local Toyota dealer and had it taken care of along with the inspection they do along with it. They told me everything looked great.
    A couple of days later I had to drive from Denver, CO to Billings MT and back. (about 600mi one way) On the way back, about an hour and a half in, the car slowed down and I had to pull to the side. There was a terrible sound coming from the engine. I had it towed to the Toyota dealer in Sheridan, WY and long story short I threw a rod and the engine was blown.
    Initially, I thought that there was something that the dealer did wrong during the oil change that caused it to happen. Apparently, all of the plugs are tight, the filter is on right and there must have been enough oil to get to Billings. I've been in communication with the dealer in Sheridan and the dealer here and it sounds like there's no evidence of anything they did wrong and likely won't do anything about fixing it. But it seems very suspicious that a car that ran perfectly fine would do that. I saw no oil light, no leaking oil, and no burning oil smell.
    Am I just that unlucky that an engine with 109k miles on it would blow? Or did something go wrong with the oil change?
  2. RacerX
    RacerX Junior Member
    Des Moines
    Hello, this is just my second post and also have a 07 Prius. Unfortunately, I know that if your very low on oil the red warning triangle will come on. If you didn't see the red warning triangle before it stopped running, then I would say it is pretty unlikely the dealer did anything wrong like not put the oil in or forgot the drain plug. My Prius burns about a half quart every 500 miles and it doesn't smoke, smell or leak any oil at all.
  3. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
    I will speculate that previous owner(s) never checked the engine oil level as required. And probably never topped off upto the top FULL mark on the oil dipstick. Unfortunately for you, the years of abuse finally mainifested itself.
    page 325 of 2007 Owner's Manual. page 404 of 2007 Owner's Manual.
    upload_2019-6-24_23-0-25.png upload_2019-6-24_23-2-22.png upload_2019-6-24_23-3-36.png
    Did you check the engine oil level before you started the trip and before you started the return leg? Did you check the engine oil level at any point during the trip: rest, food, bathroom, gas?
    Is the mileage accurate on your 2007? It is not unheard of bad people installing combo meters (MPH, odometer, trip meter, gear indicator), with lower miles.
    Used Gen2 engines are cheap ($500+). Labor is costly, unless you DIY.
  4. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Yes this is not an uncommon occurrence. You will find many instances of gen 2 Prius throwing rods here. Usually due to people not checking the oil.
    edthefox5 likes this.
  5. bisco
    49,505
    welcome!
    might not have put enough oil in, or perhaps they didn't tighten the drain plug
  6. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    Probably like they said previous owner almost blew engine like others said. Then played trick with oil to get next person to buy it. But trick would hold for long.
    Used to do things like that for used car lot sometimes
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    go to toyota.com/owners and join the forum. It will ask you for the cars vin so have your insurance card ready.
    Once you join can look at the cars maintenance history. Every time the car saw an authorized toyota service center it will show a service entry in the log.
    See if the car has any sketchy history like brought in for bad engine noises and engine proclaimed damaged and it was traded in on the spot. Off the car goes to auction for the next sucker looking for a "deal".
  8. Dave Brewster
    Littleton, CO
    Thanks all for the input. I'm getting a better picture now of what went wrong. I'll probably still put a new engine in an be extra diligent in checking the oil.
  9. exstudent
    2,213
    901
    Torrance, CA
    #9 exstudent, Jun 26, 2019
