Prius Break-In *Surge* MPG-FE *Delta* Phenomenon
Discussion in 'Gen 2 Prius Fuel Economy' started by catgic, Sep 6, 2007.
  1. catgic
    catgic Mastr & Commandr Hybrid Guru
    586
    140
    HTTP 404 Not Found
    HTTP 404 Not Found
  2. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    Are you sure this is not due to the lesser weight of less fuel on board? Perhaps you never noticed it before. I seem to get at least several mpg less upon filling the tank, and mpg gradually increases as the tank is consumed. This seems to repeat with every tank. Maybe I will go on a starvation diet and after a few months see how much my mpg has increased :blink:
  3. catgic
    586
    140
    HTTP 404 Not Found
    HTTP 404 Not Found
  4. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    You introduced several variables at once, but my guess would be that
    the wind swung around in your favor on the return trip. You pretty
    much went northwest and then returned toward the southeast, right?
    Prevailing westerlies could easily do that. There's also a certain
    amount of break-in of the *driver* that happens, and while you were
    on cruise much of the way sometimes how you handle the little routing
    bits at either end counts for a lot. I've seen MPG averages stay
    rock-steady for six hours on an interstate, and then the nice little
    warp-stealth glide into a rest stop pops it up a point or three.
    _H*
  5. bwilson4web
    15,528
    As a suggestion, make a log on your next cross country with each segment recording, start/stop miles, temperature, fuel (if you top off), speed, wind direction and speed, altitude of start/stop locations and any other notes that might apply. Then for grins, try different speed increments for the segments, 65, 70, 75, if possible.
    One other thing, there is a scanner that works very nicely with your model and I think it can record the OBD data. I don't have any experience with it but it could give more insights.
    GOOD LUCK!
  6. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    <div class='quotetop'>QUOTE(catgic @ Sep 6 2007, 04:21 PM) [snapback]508152[/snapback]</div>
    Catgic... My apologies, I didn't read your post carefully enough... thought you made both directions on 1 tank. Actually I HAVE noticed a "Surge" after I hit 5000... being the eternally curious person I am, I was thinking of many possible reasons. The problem is that my Prius goes over 2 weeks between fillups and a lot of changes can happen during that time... I changed my oil to 5w30 (do not know what the factory puts in), pumped tires to 40/38 (do not know what the dealer put in), got my EBH and started using it on the higher tank, had a BGT episode (barfing gas tank) on the higher mpg tank, the weather cooled off a little so less AC use, getting more experience driving this fantastic car, etc. I was thinking it was a combination of all of the above that gave me 66.6 mpg (pump based) on that tank, when my highest previous was 57. There are so many variables involved, I still doubt there is something that "breaks in" at around 5k miles. Just my $.02, but glad we are both getting such great numbers all of a sudden! Oh... I'm still eating the same. And I have all of them except DS9.
  7. douglas001001
    douglas001001 smug doug
    222
    Chicago
    Since everyone seems to hit it at 5000 miles, could it be that the computer expands the SoC range of the battery to the full range where it might be something less during break in?
  8. catgic
    586
    140
    HTTP 404 Not Found
    HTTP 404 Not Found
  9. kerouac906
    kerouac906 New Member
    I know very little about cars and production but is it possible that Toyota (and maybe others) use a special grade of oil in a brand new engine since they can only assume the car will be spending part of the beginning of its life not being driven while on a ship or on a lot?
    I read a few posts stating the original oil was filthy and sludgy by 5000 miles and a subsequent 5000 miles didn't make the following batch nearly as dirty...
    I have yet to hit my 5000 but I will report back when that comes around...
  10. Earthling
    Earthling New Member
    441
    Somewhere, NY
    You can get a 2-to-3 mpg difference due to elevations along your route. I've seen that going from my house to a destination that is lower in elevation. High mileage outbound, lower by 2 or 3 mpg coming home.
    Harry
