Prius break lights dim?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Katya S, Sep 25, 2018.
  1. Katya S
    Katya S Junior Member
    Usa
    I tried looking for the same issue on here but couldn't find it, so sorry if this is a repeat thread.
    Basically, I realized that both my break lights on my 2005 became dim at the same time (while I think the little middle light on top works fine). Upon closer inspection it looks like the middle of the 6 little LEDs on both is out. Is this an electrical issue or do I need to order replacements asap?
    I will go to a mechanic, but wanted to ask in case this exact situation happened to anyone already.
    Paul Schenck likes this.
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,369
    3,217
    Madison, Wisconsin
    They often do stop working over time, so maybe it is time for replacement.
    The LEDs are not separately replaceable. The entire tail light assembly must be removed. Ot sounds like a big job, but it's actually a beginner level job.
    If you have a few tools (3/8 Socket wrench, 10mm deep well socket) you can replace them in under 30 minutes.
  3. Nortnarg
    Nortnarg Prius~To go before
    83
    Blue Springs, Missouri
    I would say that your brake lights are taking a break.
    edthefox5 and bisco like this.
    49,397
    i would say your break lights are putting the brakes on.
    edthefox5 and Nortnarg like this.
  5. Usle
    Usle Active Member
    317
    139
    Me
    2018 Prius Prime
    Any sign of rodents in or around the car, a chewed on wire touching something parisitic, not a ground, but something?
    Finding a used set might save some cash, well, if everyone had dim lights after a few years it would be a problem, but, none have indicated it.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    Something parasitic?
  7. Paul Schenck
    Paul Schenck Active Member
    522
    306
    Fresno, California
    I just realized mine have this problem they work though they are dim. I’ll post what I find this weekend.
    iPhone ?
