Prius Buzz sound
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ItalianPruis, Jun 13, 2022.
  1. ItalianPruis
    ItalianPruis Junior Member
    STL
    Please listen to this video. What is this buzz sound the car makes while driving, stopped, parked and when turning off?
    07 Prius buzzing noise - YouTube
  2. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    Maybe the inverter water pump? It’s hard to tell.
  3. ItalianPruis
    STL
    I just had the inventor pump replaced on Friday. Starting make this sound on Sunday.
  4. 2010moneypit?
    314
    122
    Beaumont ca
    Do you have a Movement in the coolant reservoir for the inverter?
    Could also be air in the system.
  5. bisco
    49,429
    is it oem from a dealer?
    could also be the brake actuator
    2010moneypit? likes this.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,209
    5,901
    Columbia, SC
    Most likely your brake actuator pump running. It's located directly behind and below the inverter. It has a pump and an accumulator. Normally, the pump runs long enough to pressurize the accumulator and then turns off. A few cycles of the brake pedal will cause enough pressure drop that the pump will need to run again. If the pump is cycling with no brake pedal motion, then there is likely a leakage problem in the actuator unit itself. Very common problem on the Gen 2. The car will continue to function just fine, until the leakage gets bad enough that the pump has to run continuously, then it will likely code out for low accumulator pressure or something similar.
  7. 2010moneypit?
    314
    122
    Beaumont ca
    I agree could be the dreaded break accumulator problem.
  8. ItalianPruis
    STL
    Would super hot weather cause the sound to go off more? It is about 105 out the last 2 days here.
  9. 2010moneypit?
    314
    122
    Beaumont ca
    Does the sound cycle on and off? Try putting the car in park with ready light on and pumping the brakes. Listen Carefully you will hear the actuator pump come on. Is this the same sound you are hearing? If it is cycling often and you are not applying the brakes you have an internal or external leak (air leak)in the brake system that needs to be addressed.
  10. ChapmanF
    15,557
    Video is too short, methinks. I take it the sound you mean is the one that starts about 6.3 seconds in. Does it run for a few seconds like that, and stop, and keep repeating?
    If so, yes, it's the brake accumulator pump. It normally sounds a little like a quiet rattlesnake. Yours sounds the worst I've ever heard, makes me think it has already been running too often for a good while now, and now its bearings are also shot.
    Running too often probably started with a leaky valve in the actuator. But in a Gen 2, all this stuff is in the same one assembly, so replacing that will solve both the original problem and the secondary one.
